1 Reply Latest reply on Jun 12, 2015 5:33 AM by kajzica
    cs6 - modifying "Image catalog" script to directly export into pdf, label width, file name sorting???
    kajzica Level 1
      hello
      I frequently use this script in cs6 but have problem.
      1. Is it possible forcing script to directly export catalog to pdf into same folder where source images is???? I need to specify pdf export preset in script, dont want dialog boxes. pdf name can be as images source folder name.
      2. Label width with file name bellow picture need to be size of column, not picture width.
      3. file sorting need to be by file name in folder, not by extension.
      thanks
        • 1. Re: cs6 - modifying "Image catalog" script to directly export into pdf, label width, file name sorting???
          kajzica Level 1
          ok, number 3 sorted. now files is listed with ignoring extension
          //ImageCatalog.jsx
          //An InDesign CS6 JavaScript
          @@@BUILDINFO@@@ "ImageCatalog.jsx" 3.0.0 15 December 2009
          //Creates an image catalog from the graphic files in a selected folder.
          //Each file can be labeled with the file name, and the labels are placed on
          //a separate layer and formatted using a paragraph style ("label") you can
          //modify to change the appearance of the labels.
          //For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
          //Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com .
          //The myExtensions array contains the extensions of the graphic file types you want
          //to include in the catalog. You can remove extensions from or add extensions to this list.
          //myExtensions is a global. Mac OS users should also look at the file types in the myFileFilter function.
          main();
          function main(){
            var myFilteredFiles;
            //Make certain that user interaction (display of dialogs, etc.) is turned on.
            app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
            myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai"]
            //Display the folder browser.
            var myFolder = Folder.selectDialog("Select the folder containing the images", "");
            //Get the path to the folder containing the files you want to place.
            if(myFolder != null){
            if(File.fs == "Macintosh"){
            myFilteredFiles = myMacOSFileFilter(myFolder);
            else{
            myFilteredFiles = myWinOSFileFilter(myFolder);
            if(myFilteredFiles.length != 0){
            myDisplayDialog(myFilteredFiles, myFolder);
            alert("Done!");
          //Windows version of the file filter.
          function myWinOSFileFilter(myFolder){
            var myFiles = myFolder.getFiles("*");
            var myFilteredFiles = new Array;
              for(var i = 0, l = myFiles.length; i<l; ++i){
                  var jeSlika = false;
                  for(var j = 0, m = myExtensions.length; j<m; ++j){
                      if(myFiles[i].name.search(myExtensions[j]) != -1){
                          jeSlika = true;
                          break;
                  if(!jeSlika){myFiles.splice(i,1); l--; i--;}
              return myFiles;
          /* for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
            myExtension = myExtensions[myExtensionCounter];
                  myFiles = myFolder.getFiles("*"+ myExtension);
            if(myFiles.length != 0){
            for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
            myFilteredFiles.push(myFiles[myFileCounter]);
            return myFilteredFiles;*/
          function myMacOSFileFilter(myFolder){
            var myFilteredFiles = myFolder.getFiles(myFileFilter);
          //Mac OS version of file filter
          //Have to provide a separate version because not all Mac OS users use file extensions
          //and/or file extensions are sometimes hidden by the Finder.
          function myFileFilter(myFile){
            var myFileType = myFile.type;
            switch (myFileType){
            case "JPEG":
            case "EPSF":
            case "PICT":
            case "TIFF":
            case "8BPS":
            case "GIFf":
            case "PDF ":
            return true;
            break;
            default:
            for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
            var myExtension = myExtensions[myCounter];
            if(myFile.name.indexOf(myExtension)>-1){
            return true;
            break;
            return false;
          function myDisplayDialog(myFiles, myFolder){
            var myLabelWidth = 112;
            var myStyleNames = myGetParagraphStyleNames(app);
            var myLayerNames = ["Layer 1", "Labels"];
            var myDialog = app.dialogs.add({name:"Image Catalog"});
            with(myDialog.dialogColumns.add()){
            with(dialogRows.add()){
            staticTexts.add({staticLabel:"Information:"});
            with(borderPanels.add()){
            with(dialogColumns.add()){
            staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
            staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
            staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
            staticTexts.add({staticLabel:myFiles.length + ""});
            staticTexts.add({staticLabel:"Options:"});
            staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
            var myNumberOfRowsField = integerEditboxes.add({editValue:5});
            staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
            var myNumberOfColumnsField = integerEditboxes.add({editValue:4});
            staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
            var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
            staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
            var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
            with (dialogRows.add()){
            staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
            var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
            var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
            var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
            var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
            staticTexts.add({staticLabel:""});
            var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
            with (myLabelsGroup){
            //Label type
            staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
            var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
            //Text frame height
            staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
            var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
            //Text frame offset
            staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
            var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
            //Style to apply
            staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
            var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
            //Layer
            staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
            var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
                  var myResult = myDialog.show();
                  if(myResult == true){
            var myNumberOfRows = myNumberOfRowsField.editValue;
            var myNumberOfColumns = myNumberOfColumnsField.editValue;
            var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
            var myFitProportional = myFitProportionalCheckbox.checkedState;
            var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
            var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
            var myHorizontalOffset = myHorizontalOffsetField.editValue;
            var myVerticalOffset = myVerticalOffsetField.editValue;
            var myMakeLabels = myLabelsGroup.checkedState;
            var myLabelType = myLabelTypeDropdown.selectedIndex;
            var myLabelHeight = myLabelHeightField.editValue;
            var myLabelOffset = myLabelOffsetField.editValue;
            var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
            var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
            myDialog.destroy();
            myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
            else{
            myDialog.destroy();
          function myGetParagraphStyleNames(myDocument){
            var myStyleNames = new Array;
            var myAddLabelStyle = true;
            /*for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
            myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
            if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
            myAddLabelStyle = false;
            if(myAddLabelStyle == true){
            myStyleNames.push("label");
            return myStyleNames;
          function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
            var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
            var myParagraphStyle, myError;
            var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
            var myDocument = app.documents.add();
            myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
            myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
            var myDocumentPreferences = myDocument.documentPreferences;
            var myNumberOfFrames = myFiles.length;
            var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
            if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
            myNumberOfPages++;
            //If myMakeLabels is true, then add the label style and layer if they do not already exist.
            if(myMakeLabels == true){
            try{
            myLabelLayer = myDocument.layers.item(myLayerName);
            //if the layer does not exist, trying to get the layer name will cause an error.
            myLabelLayer.name;
            catch (myError){
            myLabelLayer = myDocument.layers.add({name:myLayerName});
            //If the paragraph style does not exist, create it.
            try{
            myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
            myParagraphStyle.name;
            catch(myError){
            myDocument.paragraphStyles.add({name:myLabelStyle});
            myDocumentPreferences.pagesPerDocument = myNumberOfPages;
            myDocumentPreferences.facingPages = false;
            var myPage = myDocument.pages.item(0);
            var myMarginPreferences = myPage.marginPreferences;
            var myLeftMargin = myMarginPreferences.left;
            var myTopMargin = myMarginPreferences.top;
            var myRightMargin = myMarginPreferences.right;
            var myBottomMargin = myMarginPreferences.bottom;
            var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
            var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
            var myColumnWidth = myLiveWidth / myNumberOfColumns
            var myFrameWidth = myColumnWidth - myHorizontalOffset
            var myRowHeight = (myLiveHeight / myNumberOfRows)
            var myFrameHeight = myRowHeight - myVerticalOffset
            var myPages = myDocument.pages;
            // Construct the frames in reverse order. Don't laugh--this will
            // save us time later (when we place the graphics).
            for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
            myPage = myPages.item(myCounter);
            for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
            myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
            myY2 = myY1 + myFrameHeight;
            for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
            myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
            myX2 = myX1 + myFrameWidth;
            myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
            // Because we constructed the frames in reverse order, rectangle 1
            // is the first rectangle on page 1, so we can simply iterate through
            // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
            for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
            myFile = myFiles[myCounter];
            myRectangle = myDocument.rectangles.item(myCounter);
            myRectangle.place(File(myFile));
            myRectangle.label = myFile.fsName.toString();
            //Apply fitting options as specified.
            if(myFitProportional){
            myRectangle.fit(FitOptions.proportionally);
            if(myFitCenterContent){
            myRectangle.fit(FitOptions.centerContent);
            if(myFitFrameToContent){
            myRectangle.fit(FitOptions.frameToContent);
            //Add the label, if necessary.
            myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
            if (myRemoveEmptyFrames == 1){
            for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
            if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
            myDocument.rectangles.item(myCounter).remove();
            else{
            //As soon as you encounter a rectangle with content, exit the loop.
            break;
          //Function that adds the label.
          function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
            var myDocument = app.documents.item(0);
            var myLabel;
            var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
            var myLabelLayer = myDocument.layers.item(myLayerName);
            var myLink =myFrame.graphics.item(0).itemLink;
            //Label type defines the text that goes in the label.
            switch(myLabelType){
            //File name
            case 0:
            myLabel = myLink.name;
            break;
            //File path
            case 1:
            myLabel = myLink.filePath;
            break;
            //XMP description
            case 2:
            try{
            myLabel = myLink.linkXmp.description;
            if(myLabel.replace(/^\s*$/gi, "")==""){
            throw myError;
            catch(myError){
            myLabel = "No description available.";
            break;
            //XMP author
            case 3:
            try{
            myLabel = myLink.linkXmp.author
            throw myError;
            catch(myError){
            myLabel = "No author available.";
            break;
            var myX1 = myFrame.geometricBounds[1];
            var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
            var myX2 = myFrame.geometricBounds[3];
            var myY2 = myY1 + myLabelHeight;
            var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
            myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
            myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
