ADE 4.0.3 will not install on my XP SP3 machine. First I uninstalled ADE 3.x. The ADE_4.0_Installer.exe does its thing. (One oddity is that the installer zips along until it extracts the file SymCCIS.dll but it eventually finishes.) I click the Close button, a message box follows: migration has encountered a problem and needs to close... At this point ADE is partially installed and doesn't work.
The Event Viewer show a NET Runtime error, Event ID 1026.
Application: migration.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.DllNotFoundException
Stack:
(a lot of info from the stack follows)
This happens regardless of what I try. Some of the failed sequences I've tried are:
1. Follow suggested steps from Adobe. Downloaded the installer with 3 different browsers. The 3 files are identical.
2. Turned off firewall and virus scanner.
3. Tried to install in Safe Mode.
4. Ran Windows Update and installed all available updates.
The routine is pretty much the same. Make a change on my system, install fails, remove program, reboot. Any suggestions for breaking out of this loop?
Have something to add?
