4 Replies Latest reply on Jun 12, 2015 8:56 AM by A.T. Romano
    publish and share problems
    tstanfordjr
      While trying to render and upload to Adobe I get an error when it trys to upload
        • 1. Re: publish and share problems
          I do not understand what you wrote... uploading is what you do FROM your computer TO a web site... what are you uploading, and what is the web site?
          The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830 may help
          • 2. Re: publish and share problems
            tstanfordjr Level 1
            The adobe website it tells you to in the elements program to archive it
            Sent from my iPhone
            • 3. Re: publish and share problems
              A.T. Romano Level 7
              tstanfordjr
              What version of Premiere Elements and on what computer operating system is it running?
              You say that you get an error when you try to upload. And, by "uploading", do you mean "import" using something like Add Media or Get Media/Files and Folders?
              If you get the error when you try to bring files into the project
              1. What is the exact wording of the error message?
              2. What is a description of the files that trigger the error message
              Video Compression
              Audio Compression
              Frame Size
              Frame Rate
              Interlaced or Progressive
              File Extension
              Pixel Aspect Ratio
              If you do not know, the brand/model/settings of the camera the recorded the file should give us valuable information regarding the description of your source file.
              3. You mention this problem related to "rendering" and "uploading", please clarify.
              a. By rendering, do you mean exporting to file saved to the computer hard drive or burn to disc?
              or
              b. Rendering as in Timeline rendering to get the best possible preview in the Edit area monitor?
              Let us start here and then decide what next based on the details in your reply.
              Any questions or need clarification, please do not hesitate to ask.
              Thank you.
              ATR
              • 4. Re: publish and share problems
                A.T. Romano Level 7
                tstanfordjr
                When you import your files into a project, all you get in the project are copies of the files which are housed on the computer hard drive. But, those copies in the project need to trace back to the original files on the hard drive. If you move, delete, or rename files and folders that went into the project after the project is saved closed, you break that connection.
                But, if you need to move, delete, or rename files and folders and do not want to get into bad project media - reconnect issues, you can use the File Menu/Project Archiver and its Archive Project or Copy Project option to save yourself. This action will generate a folder that will have copies of the source media and copies of the project file - and you open the project file from this folder. It has its own media with it.
                Adobe Premiere Elements Help | Archiving projects
                But, please explain what you want to do. See post 3. Then we can decide what archiving of projects has to do with the thread question that you posted.
                Thank you.
                ATR
