0 Replies Latest reply on Nov 28, 2006 3:08 AM by Thomas Friedl
    ScrollControlBase
    Thomas Friedl Level 1
      I'm working on the Adobe Labs Scheduling Framework. The "main component" is based on the ScrollControlBase class. My problem is now, that by using the mouse-wheel a negative value for the vertical scroll position is possible. I allready "fixed" it by catching the scroll event, checking for a value less then zero and if so setting it to zero.
      But it still scrolls a little bit into the negative area and it just doesn't look/feel good because there is a certain dealy until it is set back to zero.
      Is it possible to prevent negative scroll positions? I couldn't find any properties, but my tests with for example a canvas showed that this component prevents it.
