Hi I have just purchased PSE 13 for windows 8 and when I run setup.exe after downloading, I get an error stating "Installer failed to initialise, this could be due to a missing file, please download adobe support advisor to diagnose the issue". adobe support advisor is discontinued so that isn't at all useful. Any ideas how to install?
start at the top and work your way down applying applicable fixes until your problem is resolved.
if cc (win): https://helpx.adobe.com/creative-cloud/kb/creative-cloud-desktop-application-failed.html
if, your error is:
"Installer failed to initialize. File not found." or "Installer failed to initialize. This could be due to missing files."
first, rename OOBE Folder to OOBE.old.
to find OOBE:
64 bit win OS: Program Files x86\Common Files\Adobe\OOBE
32 bit win OS: Program Files \Common Files\Adobe\OOBE
m
...Copy link to clipboard
if, your error is:
to find OOBE:
mac os: HD>library>application support>adobe>caps
mac os: USER>library>application support>adobe>OOB
if that fails or isn't the exact error you see, uninstall, clean (http://www.adobe.com/support/contact/cscleanertool.html) and reinstall.
if you're using a dvd to install:
copy the disc contents to a desktop directory and install from that directory.
if you're using a mac:
1. Try to Create a new user account in Mac with Administrator Priviledges.
2. Login to the New user, Navigate to Mac HD> Application> Utilities> Adobe Installer folder, Locate products like Adobe Reader, Adobe Flash, Adobe Air and un-install them
3. Navigate to User Library> Application Support> Adobe and move Adobe to Trash.
4. Navigate to Mac HD> Library> Application Support> Adobe and move Adobe to Trash.
5. Start the installation again.
if everything applicable above fails, check your installation logs:
http://helpx.adobe.com/photoshop-elements/kb/troubleshoot-install-using-logs-elements.html
