3 Replies Latest reply on Jun 18, 2015 7:30 AM by dionbalson
    Check mark not showing up in dynamic stamp after applying to document...is there a common reeason for this?
    JohnnyBQue
      wasn't going to post the code but I know the first answer would have a comment "I would need to see the code" so I've posted it below....
      I just need the check mark to show up in the stamp after stamping the document....the dialog box works great (text boxes that is)....I'm able to place check marks in all the check boxes in the dialog box, but again they don't show after stamping...
      I've only included the code for 1 of the check boxes just to get it working the duplic the other 4.
      var dialog =
                        DueValue: "",
                  WorkOrderValue: "",
               QuantityValue: "",
              IssueDateValue: "",
                IssueToValue: "",
                cb1Value:false,
                cb2Value:false,
                cb3Value:false,
                cb4Value:false,
                cb5Value:false,
              initialize:function(dialog)
      var diginit=
              "Chk1":this.cb1Value,
              "Chk2":this.cb2Value,
              "Chk3":this.cb3Value,
              "Chk4":this.cb4Value,
              "Chk5":this.cb5Value,
              dialog.load(diginit);
              commit:function (dialog) // called when OK pressed
                      var results = dialog.store();
                      this.DueValue = results["txt1"];
                      this.WorkOrderValue = results["txt2"];
              this.QuantityValue = results["txt3"];
              this.IssueDateValue = results["txt4"];
              this.IssueToValue = results["txt5"];
              var oRslt=dialog.store();
              this.cb1Value=oRslt["Chk1"];
              this.cb2Value=oRslt["Chk2"];
              this.cb3Value=oRslt["Chk3"];
              this.cb4Value=oRslt["Chk4"];
              this.cb5Value=oRslt["Chk5"];
                       description:
                          name: "Control Stamp Information",    // Dialog box title
                          elements:
                                type: "view",
                                elements:
                                                             type: "static_text",
                                                             item_id: "txt1",
                                                             type: "edit_text",
                                                             multiline: true,
                                                             width: 100,
                                                             height: 30
                                                             item_id: "txt2",
                                                             type: "edit_text",
                                                             multiline: true,
                                                             width: 100,
                                                             height: 30
                                                             item_id: "txt3",
                                                             type: "edit_text",
                                                             multiline: true,
                                                             width: 100,
                                                             height: 30
                                                             name: "Issue Date: ",
                                                             item_id: "txt4",
                                                             type: "edit_text",
                                                             multiline: true,
                                                             width: 100,
                                                             height: 30
                                                             name: "Issue To: ",
                                                             item_id: "txt5",
                                                             type: "edit_text",
                                                             multiline: true,
                                                             width: 100,
                                                             height: 30
                                     type: "view",
                                     char_height: 10,
                                     elements:
                                                             item_id: "stat",
                                                             name: "Check What applies",
                                                             char_width: 15,
                                                             alignment: "align_fill",
                                                             font: "dialog",
                                           type: "view",
                                           char_width: 8,
                                           char_height: 8,
                                           align_children: "align_top",
                                           elements:
                                                  type: "view",
                                                  char_width: 8,
                                                  char_height: 8,
                                                  elements:
                                                             type: "check_box",
                                                             item_id: "Chk1",
                                                             name: "1st, 10th, Last",
                                                             type: "check_box",
                                                             item_id: "Chk2",
                                                             type: "check_box",
                                                             item_id: "Chk3",
                                                             type: "check_box",
                                                             item_id: "Chk4",
                                                             type: "check_box",
                                                             item_id: "Chk5",
                                                             name: "Final Inspection Required",
                                                             type: "ok_cancel",
                                                             ok_name: "Ok",
                                                             cancel_name: "Cancel"
        if(event.source.forReal && (event.source.stampName == "#TabIjeb2ZLdGVyiRhzvfNA"))
        if ("ok" == app.execDialog(dialog))
         // var cMsg = dialog.DueValue;
         // event.value = "\n" + cMsg;
         // event.source.source.info.ControlStamp = cMsg;
          cMsg = "\n" + dialog.DueValue;
          this.getField("Due").value = cMsg;
          cMsg = "\n" + dialog.WorkOrderValue;
          this.getField("WorkOrder").value = cMsg;
          cMsg = "\n" + dialog.QuantityValue;
          this.getField("Quantity").value = cMsg;
          cMsg = "\n" + dialog.IssueDateValue;
          this.getField("IssueDate").value = cMsg;
          cMsg = "\n" + dialog.IssueToValue;
          this.getField("IssueTo").value = cMsg;
          // this.getField("cb1").checkThisBox(0, DiaBox.cb1Value);   these didn't work either....
          // this.getField("cb2").checkThisBox(0, DiaBox.cb2Value);
          // this.getField("cb3").checkThisBox(0, DiaBox.cb3Value);
          // this.getField("cb4").checkThisBox(0, DiaBox.cb4Value);
          // this.getField("cb5").checkThisBox(0, DiaBox.cb5Value);
          this.getField("cb1").value = dialog.cb1Value ? "Yes" : "Off";   // Thanks George for this....This is what I'm trying now....should I be using "OFF" ?..?
