0 Replies Latest reply on Jun 15, 2015 8:29 AM by stuarts24
    Dynamic Stamp - Prepopulate text field
    stuarts24
      I have a dynamic stamp that I created but I need to add a value, if it exists, which is located under "Document Properties/Custom" to a text box on the dialog when it initially displays.  The Name of the Value in Document Properties/Custom is "tPExhRY1".  For the life of me I cannot figure out how to make this happen.  The scripting I have so far is:
      var dialog = {
              ExhNum: "",
              commit:function (dialog) { // called when OK pressed
                      var results = dialog.store();
                      this.ExhNum = results["txt1"];
              description:
                      name: "Exhibit Stamp",    // Dialog box title
                      elements:
                                      type: "view",
                                      elements:
                                                      name: "Exhibit Number:",
                                                      type: "static_text",
                                                      item_id: "txt1",
                                                      type: "edit_text",
                                                      char_width: 8
                                                      type: "ok_cancel",
                                                      ok_name: "Ok",
                                                      cancel_name: "Cancel"
      if(event.source.forReal && (event.source.stampName == "#JcvSpJdDr50IYVmKy6fCED"))
        if ("ok" == app.execDialog(dialog))
          var cMsg = dialog.ExhNum;
          event.value = cMsg;
          event.source.source.info.tPExhRY1 = cMsg;
          this.getField("tPExhRY1").value = cMsg;
      Any assistance would be greatly appreciated!
