3 Replies Latest reply on Jun 16, 2015 6:33 AM by rezun8
    Something like a universal clickTAG AS3 code?
    ricardsp79919285
      Hello! I got this code from my client to be used in a set of banners for a campaign:
      on (release) // universal clicktag
            if (ClickTag != null) { getURL(ClickTag, "_blank"); }
      else if (clickTAG != null) { getURL(clickTAG, "_blank"); }
      else if (clicktag != null) { getURL(clicktag, "_blank"); }
      else if (_root.link1 != null) { getURL(_root.link1, "_blank"); }
      else if (_root.clickTAG != null) { getURL(_root.clickTAG, "_blank"); }
      This is AS2 and I am not sure if it works, but since they gave it to me, it should. The question - is there a similar AS3 version out there? Since I am using Flash Professional CC.
      I was trying something like this:
      Link.addEventListener(
        MouseEvent.CLICK,
        function():void {
          if (root.loaderInfo.parameters.clickTAG.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters.clickTAG), "_blank"
          else if (root.loaderInfo.parameters.clickTag.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters.clickTag), "_blank"
          else if (root.loaderInfo.parameters.clicktag.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters.clicktag), "_blank"
          else if (root.loaderInfo.parameters._root.link1.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters._root.link1), "_blank"
          else if (root.loaderInfo.parameters.ClickTag.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters.ClickTag), "_blank"
          else if (root.loaderInfo.parameters._root.clickTAG.substr(0,5) == "http:") {
            navigateToURL(
              new URLRequest(root.loaderInfo.parameters._root.clickTAG), "_blank"
      But no luck, it was running only the first clickTAG version. Any help is appreciated.
        • 1. Re: Something like a universal clickTAG AS3 code?
          Colin Holgate MVP & Adobe Community Professional
          You're getting a substring of an object that may not exist. Try taking out the substr parts.
          • 2. Re: Something like a universal clickTAG AS3 code?
            ricardsp79919285 Level 1
            When removing the substr parts it does solve the problem for most of the clickTAG versions except the two with _root appendix. I am not sure if there are advertising sites using this kind of syntax. Need to check on that, but for most cases this code is valid. Thanks for your help!
            • 3. Re: Something like a universal clickTAG AS3 code?
              rezun8 Level 4
              this is what we use for ClickTAG tracking for use in DoubleClick Studio:
              AS3
              //CLICK TAG
              function handleClick(mouseEvent:MouseEvent):void {
                  var interactiveObject:InteractiveObject = mouseEvent.target as InteractiveObject;
                  var li:LoaderInfo = LoaderInfo(interactiveObject.root.loaderInfo);
                  var url:String = li.parameters.clickTag;
                  if (url) {
                      if (ExternalInterface.available) {
                          var userAgent:String = ExternalInterface.call('function(){ return navigator.userAgent; }');
                          if (userAgent.indexOf("MSIE") >= 0) {
                              ExternalInterface.call('window.open', url, '_blank');
                          } else {
                              navigateToURL(new URLRequest(url), '_blank');
                      } else {
              clickTag_btn.addEventListener(MouseEvent.MOUSE_UP,handleClick);
