1 Reply Latest reply on Jun 15, 2015 9:32 AM by sinious
    How to make a button to overlay all objects?
    azkianury
      I'm currently making a flash application. In the application, I'm loading an swf file inside a frame. Here's the code:
      stop();
      var url1:URLRequest = new URLRequest("Complete The Words Game 1.swf");
      myLoader.load(url1);
      addChild(myLoader);
      myLoader.scaleX = 1.8;
      myLoader.scaleY = 1.8;
      myLoader.x = 190;
      addChild(backtopractice_button);
      backtopractice_button.x=20;
      backtopractice_button.y=610;
      backtopractice_button.addEventListener (MouseEvent.CLICK, backtopractice);
      And I want to bring the "backtopractice_button" to the very front to overlay everything, even the SWF file too. Is it possible to do this? Thanks.
        • 1. Re: How to make a button to overlay all objects?
          sinious Most Valuable Participant
          You can set the index of any DisplayObject using setChildIndex:
          DisplayObjectContainer - Adobe ActionScript® 3 (AS3 ) API Reference
          I'm not sure where "backtopractice_button" is coming from (assuming code you're not posting) but assuming it's added via code (you can't change things on the timeline and I don't think you'd be running addChild() on a timeline object). So find the stage's highest index with .numChildren and set it to that - 1.
          Simple all code example of flipping 2 Sprites added (frame script):
          import flash.display.Sprite;
          var a:Sprite = new Sprite();
          a.name = 'IAm-A'; // set a name so we know which is which
          this.addChild(a); // 'this' is just representing the stage
          var b:Sprite = new Sprite();
          b.name = 'IAm-B';
          this.addChild(b);
          trace(this.getChildAt(1).name); // IAm-B
          // swap
          this.setChildIndex(a, this.numChildren - 1);
          trace(this.getChildAt(1).name); // IAm-A
          So for you, should be simply:
          this.setChildIndex(backtopractice_button, this.numChildren - 1);
