2 Replies Latest reply on Jul 25, 2016 9:04 AM by Jeff Almasol
    FAQ: What's the difference between using artwork from Illustrator or Photoshop?
    Jeff Almasol Adobe Employee
      Although you can use Illustrator or Photoshop files with Character Animator, note the following differences:
      • Illustrator artwork can be Wiggler-ed (and the Wiggler behavior is applied by default).
      • You can scale or zoom into Illustrator artwork beyond 100% and rendering stays sharp.
      • If an Illustrator file uses options that don't render by default in Character Animator (e.g., gradients), you can enable the Render As Image option in the Properties panel after selecting in the Puppet panel any skin layer from the file. This option disables wiggling.
