1 Reply Latest reply on Jun 15, 2015 3:37 PM by isa_orianthi
    Hyperlinks to URL changing when exporting to PDF
    isa_orianthi Level 1
      I am using InDesign CS6 to create a document with many links to URLs. I have found that the conversion process from INDD to PDF (Export to PDF) is changing some special characters in the link, essentially breaking the hyperlinks in the PDF (for example, an equation symbol "=" AND the question mark symbol "?" BOTH get converted to their html character codes--%3D and %3F, respectively-- and the links are broken, "404 Error."
      Process:
      1. Highlight desired text
      2. Right-click > Interactive > New Hyperlink
      3. Link To: URL
      4. Destination URL: Paste the link location
      5. Apply character style "hyperlink"
      6. File > Adobe PDF Presets
      Adobe PDF Presets Summary:
      Description
      PDF Preset: Adobe PDF Preset 1
      Compatibility: Acrobat 5 (PDF 1.4)
      Standards Compliance: None
      General
          Pages: All
          Spreads: Off
          Generate Thumbnails: Off
          Optimize PDF: Off
          Create Acrobat Layers: N/A
          Export Layers: Visible and Printable Layers
          Include Bookmarks: Off
          Include Hyperlinks: On
          Export Nonprinting Objects: Off
          Export Visible Guides and Baseline Grids: Off
          Create Tagged PDF: Off
          Interactive Elements: Do Not Include
      Compression
          Color Images
              Bicubic Downsample at: 300 ppi
              for images above: 330 ppi
              Compression: ZIP
              Tile Size: N/A
              Quality: 8 Bit
          Grayscale Images
              Compression: ZIP
              Tile Size: N/A
              Quality: 8 Bit
          Monochrome Images
              No Sampling Change
              for images above: 1800 ppi
              Compression: CCITT Group 4
          Compress Text and Line Art: Off
          Crop Image Data to Frames: On
      Marks and Bleeds
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Page Mark Type: Default
          Weight: 0.25 pt
          Offset: 0p6
          Use Document Bleed Settings: Off
          Bleed Top: 0p0
          Bleed Bottom: 0p0
          Bleed Inside: 0p0
          Bleed Outside: 0p0
          Include Slug Area: Off
      Output
          Color Conversion: No Color Conversion
          Destination: N/A
          Profile Inclusion Policy: Include Tagged Source Profiles
          Simulate Overprint: N/A
          Output Intent Profile Name: N/A
          Output Condition: N/A
          Output Condition Identifier: N/A
          Registry Name: N/A
      Advanced
          Subset Fonts Below: 100%
          Omit PDF: Off
          Omit EPS: Off
          Omit Bitmap Images: Off
          Transparency Flattener Preset: N/A
          Ignore Spread Overrides: N/A
      Security
          N/A
      Warnings
