5 Replies Latest reply on Jun 16, 2015 7:59 AM by jasonvp
    Merging Videos via Command Line
    juliusf13648064
      Hi there,
      my question is a bit noobie, but i am not sure After Effects is capable of this.
      I want to automate a large number of video exports.
      Basicly i want to merge 3 videos together.
      Intro - Content - Credit
      The content has varying length.(This seems to be the main problem)
      So i think it is not possible to replace an video link inside the After Effects project if the content length is different.
      Is that right?
      I would love to use something like this:
      aerender -project projectFile.aep -replaceVideo nameInProject path/to/file.mov
      Any advices or ideas?
      Thanks in advance
        • 1. Re: Merging Videos via Command Line
          Dave LaRonde Level 6
          You'd probably be better off doing this kind of work in Permiere Pro if you have it.  The time you would save would more than compensate for the non-automated nature of the process.
          • 2. Re: Merging Videos via Command Line
            juliusf13648064 Level 1
            With the CC subscription i got it, but i was not aware of a command line Interface of Premiere Pro.
            • 3. Re: Merging Videos via Command Line
              I don't know it can be done via command line in any Adobe application.  But this is simple editing for a job like that, PP is far faster than AE would be even if you could automate it.
              • 4. Re: Merging Videos via Command Line
                You can do this easily in ffmpeg-based tools like Handbrake. No need to involve any Adobe tools.
                Mylenium
                • 5. Re: Merging Videos via Command Line
                  jasonvp Level 3
                  I've had to come up with a similar solution on my Mac because those STUPID GoPro cameras still insist on chunking up their MP4s into 4GB "bites".  It makes working with very long GoPro footage... um.. annoying.  But, in any event, I wrote a script on my Mac to use ffmpeg and GNU's readlink (greadlink) to do the trick.
                  #!/bin/bash
                  # Path to non-system binaries that we'll need.
                  # ffmpeg, the app that just keeps giving and giving.
                  FFMPEG=/opt/local/bin/ffmpeg
                  # Need to use GNU's readlink versus OS X's system one.
                  READLINK=/opt/local/bin/greadlink
                  # Do some quick error checking.
                  if [ $# -le 2 ]
                  then
                          echo Usage: concat-vid input_vid1.mp4 input_vid2.mp4 ... input_vidN.mp4 output_vid.mp4
                          exit 1
                  fi
                  ARGS=("$@")
                  ARGC=`expr $# - 1`
                  OUTFILE=${ARGS[${ARGC}]}
                  # Do the deed
                  ${FFMPEG} -f concat -i <(printf "file \'`${READLINK} -f %s`\'\n"\
                          `echo $@ | cut -d ' ' -f 1-${ARGC}`) -codec copy ${OUTFILE}
                  I just call it with "concat-vid some-vid*.mp4 output.mp4" and it does the deed.  This works fine for h.264 mp4s.  I dunno if it works for any other format as I haven't tried it.
