3 Replies Latest reply on Jun 12, 2016 7:45 AM by 247Visuals
    Turn off sync in Adobe Premiere Clip on iOS
    Tigon Nguyen
      I'm using Premiere Clip in iOS, it auto sync my project when I create new project, I don't know how to turn off it. I have a slowly connection internet, I hate it...
        • 1. Re: Turn off sync in Adobe Premiere Clip on iOS
          bronwyn-lewis Adobe Employee
          Hi Tigon,
          Sorry you are having trouble, and thanks for your feedback. Your projects sync automatically so that you can work across devices, and so that you have the option to send your project to Premiere Pro for further refining.
          Bronwyn
          Community Manager for Premiere Clip
          • 2. Re: Turn off sync in Adobe Premiere Clip on iOS
            KoMaruyama Adobe Community Professional
            Hey Tigon,
            I have bad internet or no internet sometimes too.  As long as you've already logged in once, and are in PremiereClip, you don't need to continue your WiFi connection to keep working on your edit.
            Once your new project is created,
            • Turn off your WiFi in device settings
            • Continue to edit in PremiereClip
            • All of your pre-loaded AdobeHue libraries are available
            • All of the pre-loaded music is available
            • You can continue to use the app (I haven't found options that don't work offline yet)
            When you're done with your edit, switch out of the application and turn WiFi back on.
            the problem is that if you switch to a different wifi zone, you may get knocked out of premiereclip (like some other Adobe mobile apps)
            if you quit the app, you can't launch it again until you have wifi Access
            When you're somewhere with WiFi access (or better WiFi) and you're ready to upload your project to PremierePro, open PremiereClip and share the project(s).
            hth
            (*caveat: at the time of this post, if you change WiFi networks, and have WiFi on, you'll have to sign in again if you Quit/Restart)
            • 3. Re: Turn off sync in Adobe Premiere Clip on iOS
              247Visuals
              Hi guys at Adobe,
              do you understand that being logged out of clip and have to start over again is a mayor malfunction in an app that is meant to be used on mobiles?
              Losing work is bad. Are you in the progress of fixing this?
              #userexperiencefirst
              Kind regards,
              Patrick
              247Visuals
