7 Replies Latest reply on Jun 24, 2015 3:39 AM by Qwertyfly...
    Adding "activate some layers" to ExportDocsAsPNG24.jsx
    Ivan Carlesso
      I'de like to add this code
      function test(){
          function tryLockLayer(name){
              try{
                  lrs.getByName(name).locked = false;
              } catch(e) {
                  return;
          var doc=app.activeDocument;
          var lrs = doc.layers;
          tryLockLayer("Watermark");
          tryLockLayer("All");
          tryLockLayer("Fill");
          tryLockLayer("No fill");
          tryLockLayer("Background");
      test();
      function test1(){
              try{
                  lrs.getByName(name).visible = false;
              } catch(e) {
                  return;
      test1();
      function test2(){
              try{
                  lrs.getByName(name).visible = true;
              } catch(e) {
                  return;
      test2();
      for (i=0; i<app.documents.length; i++)
              var idoc = app.documents[i];
              //alert("+"+idoc.path+"+");
              if (idoc.path == "")
                      file = File.saveDialog ("Save file...");
                      idoc.saveAs (file);
              else
                      //alert(idoc.name);
                      if (!idoc.saved)
                              idoc.save();
                              idoc.saved = true;
      in this script
      ADOBE SYSTEMS INCORPORATED
      Copyright 2005 Adobe Systems Incorporated
      All Rights Reserved
      NOTICE:  Adobe permits you to use, modify, and
      distribute this file in accordance with the terms
      of the Adobe license agreement accompanying it.
      If you have received this file from a source
      other than Adobe, then your use, modification,
      or distribution of it requires the prior
      written permission of Adobe.
      DESCRIPTION
      This sample gets files specified by the user from the
      selected folder and batch processes them and saves them
      as PDFs in the user desired destination with the same
      file name.
      // Main Code [Execution of script begins here]
      // uncomment to suppress Illustrator warning dialogs
      // app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
      var destFolder, sourceFolder, files, fileType, sourceDoc, targetFile, pngExportOpts;
      // Select the source folder.
      sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files you want to convert to PNG', '~' );
      // If a valid folder is selected
      if ( sourceFolder != null )
          files = new Array();
          fileType = prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );
          // Get all files matching the pattern
          files = sourceFolder.getFiles( fileType );
          if ( files.length > 0 )
              // Get the destination to save the files
              destFolder = Folder.selectDialog( 'Select the folder where you want to save the converted PNG files.', '~' );
              for ( i = 0; i < files.length; i++ )
                  sourceDoc = app.open(files[i]); // returns the document object
                  // Call function getNewName to get the name and file to save the pdf
                  targetFile = getNewName();
                  // Call function getPNGOptions get the PNGExportOptions for the files
                  pngExportOpts = getPNGOptions();
                  // Export as PNG
                  sourceDoc.exportFile( targetFile, ExportType.PNG24, pngExportOpts );
                  sourceDoc.close(SaveOptions.DONOTSAVECHANGES);
              alert( 'Files are saved as PNG in ' + destFolder );
          else
              alert( 'No matching files found' );
      getNewName: Function to get the new file name. The primary
      name is the same as the source file.
      function getNewName()
          var ext, docName, newName, saveInFile, docName;
          docName = sourceDoc.name;
          ext = '.png'; // new extension for png file
          newName = "";
          for ( var i = 0 ; docName[i] != "." ; i++ )
              newName += docName[i];
          newName += ext; // full png name of the file
          // Create a file object to save the png
          saveInFile = new File( destFolder + '/' + newName );
          return saveInFile;
      getPNGOptions: Function to set the PNG saving options of the
      files using the PDFSaveOptions object.
      function getPNGOptions()
          // Create the PDFSaveOptions object to set the PDF options
          var pngExportOpts = new ExportOptionsPNG24();
          // Setting PNGExportOptions properties. Please see the JavaScript Reference
          // for a description of these properties.
          // Add more properties here if you like
          pngExportOpts.antiAliasing = true;
          pngExportOpts.artBoardClipping = true;
          //pngExportOpts.horizontalScale = 100.0;
          //pngExportOpts.matte = true;
          //pngExportOpts.matteColor = 0, 0, 0;
          pngExportOpts.saveAsHTML = false;
          pngExportOpts.transparency = true;
          //pngExportOpts.verticalScale = 100.0;
          return pngExportOpts;
      I need to activate some layers before export the PNG file.
      Ivan
        • 1. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
          Qwertyfly... Level 4
          to make this work now, are you just running your script first then running the "ExportDocsAsPNG24.jsx"?
          if so, you may find that putting your code at the start of the other script will work fine.
          would be worth checking for any conflicting variables and changing any you do find.
          • 2. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
            Ivan Carlesso Level 1
            Yes, I'm running my script first and after the other.
            The problem is that the first script works only if I first open all the files, and than I save manually every one file. After that I can run the second script that ask me a folder where the files are located.
            I'd like the approach of the second script so I'd like to insert the first script in the other.
            • 3. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
              the top script is a bit of a mess.
              do you need it to save the files? I dropped that last section of code.
              also rearranged it to reduce the amount of code and renamed functions to make it clear what they do.
              a quick test makes me think it's working correctly
              not sure why you hide all layers only to unhide some again, but left it doing that
              All Rights Reserved
              DESCRIPTION
              file name.
              var destFolder, sourceFolder, files, fileType, sourceDoc, targetFile, pngExportOpts, lrs;
              //              ADDED Script to do to each file before exporting
                           lrs = sourceDoc.layers;
                           UnLockLayer("Watermark");
                           UnLockLayer("All");
                           UnLockLayer("Fill");
                           UnLockLayer("No fill");
                           UnLockLayer("Background");
                           HideLayer("Watermark");
                           HideLayer("All");
                           HideLayer("Fill");
                           HideLayer("No fill");
                           HideLayer("Background");
                           UnHideLayer("Watermark");
                           UnHideLayer("Fill");
                           UnHideLayer("Background");
                          // Export as PNG
                  else
                  newName = "";
                  return saveInFile;
              //          Your Functions
              function UnLockLayer(name){
                      try{
                      }catch(e){
                          return;
               function HideLayer(name){
                      try{
                      }catch(e){
                          return;
              function UnHideLayer(name){
                      try{
                      }catch(e){
                          return;
              • 4. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
                I've copied the first script from the forum and modified a bit. It's a bit of a mess because I don't know scripting
                Your script works great.
                I want to hide all layers because I don't know which layers are active in the documents. If there is another way to say I want only these layers visible it's the same for me.
                And there is no need to save the files now that the first script is into the other!
                Thank you very much!
                Ivan
                • 5. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
                  It can be condensed more, and is more efficient as there are less processing steps.
                  here is improved code
                  have a look over it and compare it to the other one I posted, and maybe yours as well.
                  it should help you understand a bit more about scripting/programing.
                  All Rights Reserved
                  DESCRIPTION
                  file name.
                               // the ShowLayer function unlocks layer by name
                               // and sets to visible or hidden via a true or false statment in argument 2
                               ShowLayer("Watermark",true);
                               ShowLayer("All",false);
                               ShowLayer("Fill",true);
                               ShowLayer("No fill",false);
                               ShowLayer("Background",true);
                              // Export as PNG
                      else
                      newName = "";
                      return saveInFile;
                  //          Your Function
                   function ShowLayer(name,vis){
                          try{
                              lrs.getByName(name).visible = vis;
                          }catch(e){
                              return;
                  • 6. Re: Adding "activate some layers" to ExportDocsAsPNG24.jsx
                    Ok, I see the difference.
                    Thank you!
