• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
1
How to Change the artboard background color in Photoshop CC 2015
New Here ,
Jun 16, 2015 Jun 16, 2015
Views
150.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Jun 16, 2015 Jun 16, 2015
Just tried changing these settings:
Preferences -> Performance -> Graphics Processor Settings -> Advanced Settings... The change drawing mode to 'Normal' (mine was 'Basic'). Suddenly I'm able to change the background.
Hopes this works for all of you too.
Votes
Translate
Translate
Adobe
Adobe Employee ,
Moving the discussion to Photoshop General Discussion
Votes
Translate
Translate
Report
Report
Community Expert ,
To change the color  of the area around the image, Right click on it and make a choice from the menu that appears.
Votes
Translate
Translate
Report
Report
‌I also have trouble changing the art board background colors. Tried changing it but background stays white.
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 20, 2015 Jun 20, 2015
Is there a way to set a default value for the artboard color so I do not have to choose my favorite (dark gray) every time I create a new file?
Votes
Translate
Translate
Report
Report
New Here ,
Oct 17, 2016 Oct 17, 2016
Perfect, thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Aug 29, 2020 Aug 29, 2020
LATEST
Thank you so much, the solution was surprisngly simple and it took me a good 15 trying to figure it out! *facepalm*
Votes
Translate
Translate
Report
Report
Wondering this too. No matter what bg colour I select, everything stays white and I can't actually see the edges of the artboards...
Votes
Translate
Translate
Report
Report
New Here ,
I get the same result on my iMac late 2009. It seams to be an error with graphic cards that have less then 512MB VRAM. On my MacBook everything works fine. I hope Adobe will fix this.
Votes
Translate
Translate
Report
Report
If this is the problem (got an MBP early 2009), then indeed I hope Adobe fixes this a.s.a.p.
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
New Here ,
It works for me too. Thx
Votes
Translate
Translate
Report
Report
New Here ,
This solved my issue. Thank you!!
Votes
Translate
Translate
Report
Report
New Here ,
It solved to me too!
Votes
Translate
Translate
Report
Report
New Here ,
Jun 17, 2015 Jun 17, 2015
Worked a treat. Thanks!
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 24, 2015 Jun 24, 2015
Yes, worked for me, too. Thank you SO much for posting that.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 07, 2015 Jul 07, 2015
ITS MAGIC! thanks
Votes
Translate
Translate
Report
Report
That does not work for me. Any other ideas?
Votes
Translate
Translate
Report
Report
Apparently, you cannot change the background color if you're in CMYK. At least that's what my machine is doing.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 19, 2015 Jun 19, 2015
THANK YOU. This was driving me nuts. This fixed my problem too, switching to RGB. Although I'm really really salty that that means I can't use multiple artboards in CMYK....seems a little silly to me....they're not only useful for web design projects....
Votes
Translate
Translate
Report
Report
New Here ,
Jun 28, 2015 Jun 28, 2015
Thank you so much for CMYK to RGB recommendation! Totally fixed--able to change pasteboard color now!!
Votes
Translate
Translate
Report
Report
Nov 21, 2015 Nov 21, 2015
Well that sucks (Photoshop not you)...
Thanks, working in RGB now and got my "Borco Board" back. I read that most RIPs for commercial printing now recognize RGB and automatically convert it to CMYK, so creating artwork in RGB is really the most efficient way to go; preserves full gamut. I'll use CMYK setting in View to preview my work.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 15, 2017 Jan 15, 2017
had the same problem, nothing worked. i always had a colored stripe on the artboard but not a colored whole background. then accidentally i pulled my fingers together on the touchpad, same when u are zooming, it colored all... maybe works for u too
Votes
Translate
Translate
Report
Report
New Here ,
May 10, 2016 May 10, 2016
mine too... WHY ON EARTH would Adobe do that?!
Votes
Translate
Translate
Report
Report
New Here ,
Finally, solved it thanx
Votes
Translate
Translate
Report
Report
