I have created several illustrations in Illustrator CC 2014. After I updated to CC 2015, I opened this same file and now all of the characters' lines appear jagged and "non-vector-like". How can I fix this?
On a retina screen? Try toggling the GPU/CPU preview under the View menu.
That fixed it! Thank you so so much!
I had the same question. This fixed it. Thank you!
This helped me fix the same problem. Thanks!
I am having this same issue, I uninstalled and reinstalled Illustrator and I am still have the jagged edge issue. Toggled GPU and still nothing. What can I do?
Thank you Larry!!! that fixed it! (y)
I have the same problem as some of the guys above. The lines in illustrator CC 2015.2 appear jagged...
This is our configuration: iMac (21.5-inch, Late 2012), 2.9 GHz Intel Core i5.
We cleaned our MACs and reinstalled Illustrator but no luck. By toggling between GPU and CPU, lines always look jagged, one way or another.
Do you have any ideas? This is really frustrating..
Thank you.
Fixed it thanks a lot!
fixed. Thank you!
I can't seem to resolve this by simply toggling GPU vs CPU, it always looks jagged now, one way or another. As opposed to before.
Do you have a retina screen? If not, then try turning off the GPU acceleration in the Preferences and select the CPU preview.
No i do not have a retina screen, and I have done that.
My iMac is late 2013 model with the Nvidia GeForce GTX 780M 4GB GPU too... in case it matters, OS X is also updated to 10.10.3.
I'm attaching the sample vector images to demonstrate, prior to today's update it was all smooth...
Below is done by following every method of turning off the GPU preview from the preferences and the preview menu option. The results are the same even after restarting inbetween preference changes.
Okay so I uninstalled, and re-installed Adobe Illustrator CC 2015, following the advice of Larry G. Schneider there after and all is well. In case anyone else has similar issues with the previous solution, try that too.
@Adobe, I am intrigued to experiencing this GPU performance enhancement as soon as this feature matures or gets patched.
I just upgraded to CC 2015 and am experiencing the same issues! Ugh - all of my beautiful, smooth vectors now appear jagged. It's distracting. I've tried all the toggles suggested above, and now I'm going to attempt an uninstall/reinstall. I hope this fixes things, and it's hard to work with these ugly jagged lines!
Nope. Did not fix the problem.
This fixed it for me, thanks!
I wanted to add that this fixed another issue I was having where overlapping strokes were displaying weird. Switched to CPU preview and now they look good with no clipping
Still having the same issue with outlined text. Tried the CPU/GPU toggling and it still displays jagged in the cleaner view. Also tried uninstalling and re-installing. No improvement. CPU View looks better, but still seeing jagged lines. Especially on the "V" and "A" - anyone have insight?
CPU View
GPU View
That was what was happening to me, I had to uninstall illustrator and re-download and re-install it. Then toggle the GPU view off, you'll notice everything back to normal.
I'm still having the same jagged line problem. Tried the CPU/GPU toggled, no luck. I reinstalled the software and updated al OSX and no improvements. I'm on a 2013 Imac 27".
I am having the same trouble. I cant understand why the GPU is making the things jagged that way. 😕
Adobe, any answer?
I'm having the same issue as well after updating. I've tried all possible solutions, and my files are still jagged. This is extremely frustrating.
Please show.
Changing to CPU Preview eliminated most of the problem, but some of the strokes become jagged towards the ends, and I have no idea how to eliminate that. I don't remember this being a problem before the update.
