Hello,
I have a situation where a learner must achieve a score of 90% to pass a quiz. I am allowing infinite attempts at the quiz.
After the quiz summary slide, the learner has the opportunity to return to the beginning of the module. It is possible for the learner to go through the module once and achieve a 90% (thus satisfying the completion criteria), but without exiting the module, return to the beginning and take the quiz again. On the second attempt they could get a lower score, and upon exiting, the LMS would show them as complete (from the first time through the quiz) but with a score below 90 (from the second time through the quiz).
Is there any way to tell Captivate "hey, if they've already passed, don't let them take it again"?
I looked at the totalAttempts variable, I thought about giving them 1000 attempts and if they pass, setting their totalAttempts = 1000, but it doesn't look like that variable can be updated.
The only other thing I can think of is to create 2 branches - one with content and quiz questions, the other with just content. If they have passed the quiz and start over, they go down the content only branch. The problem with this approach is that the content is duplicated, meaning larger file sizes, twice the maintenance work, etc.
Any thoughts?
This is not the normal behavior at all. Review button, which means that no further attempts are possible, should appear when user has passed if you set Quiz attempts to Infinite.
Something must have been messed up. Did you delete embedded objects on question/score slides? Those are objects that do not have separate timeline.
The Allow User to Review the Quiz checkbox is not selected, but my testing shows that it doesn't make any difference.
The learner doesn't use the Review button to go back. After the Quiz Summary slide, there is a final content slide. That final content slide has a button that jumps back to slide 1, before the first question slide. So the learner leaves the quiz scope at the end, and jumps back prior to the start of the quiz. It's a completely new attempt, which is apparently allowed by the infinite attempts setting even when the quiz has been passed.
I've tested in v7 and v8.
I am still puzzled because I never did see such a behavior. Did you track cpQuizInfoAttempts? What are the Actions on Success, and On Failure on Quiz level?
If Passing is Continue, If Failing doesn't have a setting because Infinite Attempts is selected.
I have been experimenting with hiding the "home" button on the final content slide. If they pass the quiz, I can basically force them to exit the course. At that point the LMS gets their completion status AND their passing score. Any launches from the LMS after that point will be "review only" and will not update their status or score.
The only problem is, when they re-launch, they are taken back to the final slide, but it knows they have passed and doesn't show the "home" button. They need the "home" button to go back to the beginning. So I'm thinking I could check to see if they passed AND if the "home" button is currently visible. If it is, hide it. If it isn't, show it. However, I can't figure out how to check the visibility of the button (e.g., button_1030.visibile = 1 or button_1030.visibility = true or something like that).
Also, once they've passed once, I want the "home" button to always show. What I've described above would toggle it with every re-launch. Are user variables preserved when using SCORM or AICC? I'm thinking I may need to use a variable of my own.
