1 Reply Latest reply on Jan 5, 2007 1:42 AM by goingflex
    Flex debugger problem
    goingflex Level 1
      This is the mesage I get as stated in technote f915fe90.
      Hang or "Failed to connect; session timed out" error when using the fdb command-line debugger
      Issue
      After you start the command-line debugger for Flex, you receive the message "Attempting to launch and connect to Player using URL". After two minutes, a timeout message appears and returns the error message "Failed to connect; session timed out."
      Reason
      The problem is usually caused by one of the following:
      1. The Flash movie was not compiled with debugging on.
      2. The Flash Player on your machine is not a debugger version.
      My flash player isthe debugger version and correct. What does it mean to "compile with debugging on" in a Flex project.
      Thanks.
