5 Replies Latest reply on Aug 12, 2017 8:21 PM by Carl Von Stetten
    enable pdf service
    Daniel Mejia_427
      This is my test to create a pdf out of html:
      <cfhtmltopdf>
      this is a test <cfoutput>#now()#</cfoutput>
      </cfhtmltopdf>
      and this is the error I get:
      Error occurred while generating PDF. Reason: Error occurred while handling request.
      and the stack trace:
      coldfusion.document.webkit.PDFgErrorHandler$ServiceManagerConversionException: Error occurred while generating PDF. at coldfusion.tagext.lang.HtmlToPdfTag.handleRetryError(HtmlToPdfTag.java:1509) at coldfusion.tagext.lang.HtmlToPdfTag.handlePDFgConversionRequest(HtmlToPdfTag.java:1471) at coldfusion.tagext.lang.HtmlToPdfTag.convertToPDF(HtmlToPdfTag.java:1413) at coldfusion.tagext.lang.HtmlToPdfTag.doEndTag(HtmlToPdfTag.java:1551) at cfmis_print_pdf2ecfm1817928483.runPage(C:\Users\daniel.mejia\Development\apps\local-intra .\backlog\mis_print_pdf.cfm:11) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:246) at coldfusion.tagext.lang.IncludeTag.handlePageInvoke(IncludeTag.java:736) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:572) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at coldfusion.filter.IpFilter.invoke(IpFilter.java:45) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:487) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:42) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:142) at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:30) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94) at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:78) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62) at coldfusion.CfmServlet.service(CfmServlet.java:219) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 ) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.inspect.weinre.MobileDeviceDomInspectionFilter.doFilter(MobileDeviceDomInspect ionFilter.java:121) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:199) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:607) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
      I believe this is because the PDF service is not installed. If I remember correctly I didn't select to install PDF service during my CF11 installation many months ago. Now I do want to use but I can't figure out how to turn on/enable this service.
      How do you enable the PDF service? For meantime I can't reinstall CF11 entirely.
        • 1. Re: enable pdf service
          Anit_Kumar Adobe Employee
          Hi Daniel,
          PDF generation is supported on both Windows and Linux operating systems. First you need to verify, if PDFg service was installed or not. Under the CF Admin, check “Data & Services > PDF Service” section. If you are able to locate the local server manager for PDF, then follow Section 1. If the same is missing, then PDFg is not installed. Please look at Section 2.
          Section 1: PDFg installed
          • Start the “Local” service manager in CF Admin OR “Verify All Service Managers” to verify it.
          • Run sample code
          Section 2: PDFg not installed
          1. Donwload the Add-on service from Adobe - ColdFusion Support Center : More Downloads
          2. Follow the installation procedure after the download and complete the installation.
          3. Run sample code
          You can try the steps mentioned at PDF Generation in ColdFusion - ColdFusion, English documentation - Adobe Learning Resources and How to setup PDFg server in ColdFusion 11 on Linux | ColdFusion Solution, as well.
          Regards,
          Anit Kumar
          • 2. Re: enable pdf service
            Matthew C. Parks Level 1
            Anit,
            We are running CF Ent. and we have multiple instances of CF Running.  PDF Service Manger will not work on any instance.
            Attempting to do this:
            • Run sample code
            Nothing I mean nothing happens. You click on the Verify nothing, Click the Verify All service managers button and nothing.
            Same thing on all instances of CF.  What do we need to do to get this working?
            • 3. Re: enable pdf service
              Vikram_k1810 Adobe Employee
              Hi Matthew,
              Could you please contact us at cf.install@adobe.com to investigate further on this issue?
              Vikram
              • 4. Re: enable pdf service
                stardust27
                Problem Description:
                Recently we figured that we didn't have PDFg installed in order to use cfhtmltopdf.
                We installed it successfully on a Linux CentOS following Adobe documentation and it worked fine for a couple of days.
                Suddenly we started to receive the following error when generating PDF:
                Detail    This timeout value is obtained from the request timeout set in the ColdFusion Administrator.
                Message    The content of this document process takes more than 20 milliseconds to process.
                We stopped the service on Administration > PDF Service as suggested by some users on the Adobe Forum, but it can't be started.
                Error enabling PDF Service Manager. Check logs for more details.
                When verifying the error is:
                Connection verification failed for PDF Service Manager: localhost
                Coudn't find any adittional information in any log. Can someone please point me out some solution?
                • 5. Re: enable pdf service
                  Carl Von Stetten Adobe Community Professional & MVP
                  stardust27 I don't have a solution for you.  But you might get a better response by submitting a new thread/question for your specific issue rather than adding a comment to a year-old thread that isn't the exact same issue.  I hope someone can assist you!
                  -Carl V.
