• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Current Status of CFQUERY
Guest
May 09, 2006 May 09, 2006
Is there any way to know the status of cfquery Insert . i.e the insert was successful or aborted or any other returning Code which tells that ? .
TOPICS
Advanced techniques
Views
516
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Unless you have set up your database in an unusual manner then SQL is either successful or throws an error.
Votes
Translate
Translate
Report
Report
Guest
hmm there is way around through triggers but that not what i am looking for . so CFQUERY it self is unable to return any status. interesting.
Votes
Translate
Translate
Report
Report
LEGEND ,
You could use cftry/cfcatch and write your own message of success. In fact, if your delete query has foreign key issues, this might not be a bad idea.
Actually a better idea is to delete the related records first.
Votes
Translate
Translate
Report
Report
Contributor ,
May 10, 2006 May 10, 2006
LATEST
If you are using SQL Server, read the Books Online under Help in SQL Query Analyzer. Look into @@ROWCOUNT, RAISERROR, BEGIN TRANSACTION, ROLLBACK TRANSACTION. Also look into CFTRANSACTION in CF.
A quick, simple way is to run a select immediately following the insert. If the record is there, the insert was successful.
This is just a quick and dirty way to check. There are better options.
Votes
Translate
Translate
Report
Report
Resources
Documentation
