3 Replies Latest reply on Jun 22, 2015 7:22 AM by PaulHC
    Indesign 2015 unable to handle pdf export of heavily scaled images.
    spoonbard Level 1
      I keep getting failed pdf exports using InDesign 2015. I tracked the problem down to several images whose effective PPI is greater than 600dpi.
      If those images are hidden, the export works fine. If they're visible, it fails.
      I don't have any problem exporting the exact same file, with the exact same images at the exact same effective PPI from InDesign 2014 (I just re-installed it and tested).
      RAM isn't a problem - I have 32GB and I'm nowhere near maxing it out.
      It's evidently an issue with the new version, so I'm going to go back to using InDesign 2014 until this issue is fixed, but thought it was best to call attention to it here.
