1 Reply Latest reply on Jun 17, 2015 8:58 AM by sdsinc_pmascari
    Call function with long process
    jfb00 Level 3
      Hi All,
      How can I define a function that call a Oracle sp but right away return something?
      The sp is a long process, I can check if the process finish later with another function.
      <cffunction name="callFunctionCC" access="remote" output="false" returnformat="any">
           <cfargument name="myID" type="numeric" required="true">
           <cfset var myResult = "The process start" />
           <cfset var qryData = "" />
           <cfstoredproc procedure="TT.CALCS.getLongProcess" datasource="#application.str_dsn#">
               <cfprocparam value="#arguments.myID#" cfsqltype="cf_SQL_NUMERIC">
               <cfprocresult name="qryData">
           </cfstoredproc>
           <cfreturn myResult/>
      </cffunction>
        • 1. Re: Call function with long process
          sdsinc_pmascari Level 2
          You could wrap the process in a CFThread.  Your long process will start "behind the scenes" in a new thread and your function can return whatever.
          <cfthread name="theLongRoad">
               </cfstoredproc>
          </cfthread>
          </cffunction>
