11 Replies Latest reply on May 31, 2017 9:44 AM by oksamurai
    character animator AIF/GL Error
    Reynardine
      When I try to use Character Animator this error pops up.  I"m on Windows 7
      GPU requires an approved NVIDIA graphics card and CUDA 5.0 or later
      Any suggestions?
        • 1. Re: character animator AIF/GL Error
          Pepto-Bismol
          +1 : same problem with Nvidia Geforce GT 555M and Windows 7
          No problem with 3D in After Effect
          the latest drivers are installed...
          • 2. Re: character animator AIF/GL Error
            johnd49794080
            Same problem as well w/ Nvidia Geforce GT 555M and Windows 7.
            • 3. Re: character animator AIF/GL Error
              CoSA_DaveS Adobe Employee
              If you're already updated your driver to the latest, there's not much else you can do, sorry. We'll try to make it work with more GPUs before we're finished with the "preview" phase of Character Animator.
              • 4. Re: character animator AIF/GL Error
                Jeff Almasol Adobe Employee
                Can you try launching Character Animator immediately after restarting your machine and with no other apps (AE, web browsets, or others that might use the GPU) running to see if that makes any difference? Just checking to see if it's a problem with low vram.
                Thanks.
                • 5. Re: character animator AIF/GL Error
                  johnd49794080 Level 1
                  I've updated my driver and tried launching Character Animator alone and still have the same results..
                  • 6. Re: character animator AIF/GL Error
                    Another thing to try to help us diagnose your GPU configuration is to run the GLview utility (OpenGL Extensions Viewer - Download), taking a screenshot of the Summary page, then clicking the Report task link in the left sidebar, and then copying the Report info (right-side box) for us to examine. Thanks.
                    • 7. Re: character animator AIF/GL Error
                      Hope this is right for report...
                      Report.jpgH
                      Thanks for your help!!
                      John
                      • 8. Re: character animator AIF/GL Error
                        asadb73795724
                        Report:
                        Renderer: Intel(R) HD Graphics 3000
                        Vendor: Intel
                        Memory: 1812 MB
                        Version: 3.1.0 - Build 9.17.10.4229
                        Shading language version: 1.40 - Intel Build 9.17.10.4229
                        Max texture size: 8192 x 8192
                        Max vertex texture image units: 16
                        Max texture image units: 16
                        Max geometry texture units: 0
                        Max anisotropic filtering value: 16
                        Max viewport size: 8192 x 8192
                        Max Clip Distances: 6
                        Max samples: 4
                        Extensions: 129
                        GL_3DFX_texture_compression_FXT1
                        GL_ARB_color_buffer_float
                        GL_ARB_compatibility
                        GL_ARB_copy_buffer
                        GL_ARB_depth_buffer_float
                        GL_ARB_depth_clamp
                        GL_ARB_depth_texture
                        GL_ARB_draw_buffers
                        GL_ARB_draw_buffers_blend
                        GL_ARB_draw_elements_base_vertex
                        GL_ARB_draw_instanced
                        GL_ARB_explicit_attrib_location
                        GL_ARB_fragment_coord_conventions
                        GL_ARB_fragment_program
                        GL_ARB_fragment_program_shadow
                        GL_ARB_fragment_shader
                        GL_ARB_framebuffer_object
                        GL_ARB_framebuffer_sRGB
                        GL_ARB_half_float_pixel
                        GL_ARB_half_float_vertex
                        GL_ARB_instanced_arrays
                        GL_ARB_map_buffer_range
                        GL_ARB_multisample
                        GL_ARB_multitexture
                        GL_ARB_occlusion_query
                        GL_ARB_occlusion_query2
                        GL_ARB_pixel_buffer_object
                        GL_ARB_point_parameters
                        GL_ARB_point_sprite
                        GL_ARB_provoking_vertex
                        GL_ARB_sampler_objects
                        GL_ARB_seamless_cube_map
                        GL_ARB_shader_bit_encoding
                        GL_ARB_shader_objects
                        GL_ARB_shading_language_100
                        GL_ARB_shadow
                        GL_ARB_sync
                        GL_ARB_texture_border_clamp
                        GL_ARB_texture_buffer_object_rgb32
                        GL_ARB_texture_compression
                        GL_ARB_texture_compression_rgtc
                        GL_ARB_texture_cube_map
                        GL_ARB_texture_env_add
                        GL_ARB_texture_env_combine
                        GL_ARB_texture_env_crossbar
                        GL_ARB_texture_env_dot3
                        GL_ARB_texture_float
                        GL_ARB_texture_non_power_of_two
                        GL_ARB_texture_query_lod
                        GL_ARB_texture_rectangle
                        GL_ARB_texture_rg
                        GL_ARB_texture_rgb10_a2ui
                        GL_ARB_timer_query
                        GL_ARB_transpose_matrix
                        GL_ARB_uniform_buffer_object
                        GL_ARB_vertex_array_bgra
                        GL_ARB_vertex_array_object
                        GL_ARB_vertex_buffer_object
                        GL_ARB_vertex_program
                        GL_ARB_vertex_shader
                        GL_ARB_vertex_type_2_10_10_10_rev
                        GL_ARB_window_pos
                        GL_ATI_separate_stencil
                        GL_EXT_abgr
                        GL_EXT_bgra
                        GL_EXT_blend_color
                        GL_EXT_blend_equation_separate
                        GL_EXT_blend_func_separate
                        GL_EXT_blend_minmax
                        GL_EXT_blend_subtract
                        GL_EXT_clip_volume_hint
                        GL_EXT_compiled_vertex_array
                        GL_EXT_draw_buffers2
                        GL_EXT_draw_range_elements
                        GL_EXT_fog_coord
                        GL_EXT_framebuffer_blit
                        GL_EXT_framebuffer_multisample
                        GL_EXT_framebuffer_object
                        GL_EXT_gpu_program_parameters
                        GL_EXT_multi_draw_arrays
                        GL_EXT_packed_depth_stencil
                        GL_EXT_packed_float
                        GL_EXT_packed_pixels
                        GL_EXT_rescale_normal
                        GL_EXT_secondary_color
                        GL_EXT_separate_specular_color
                        GL_EXT_shadow_funcs
                        GL_EXT_stencil_two_side
                        GL_EXT_stencil_wrap
                        GL_EXT_texture3D
                        GL_EXT_texture_array
                        GL_EXT_texture_compression_s3tc
                        GL_EXT_texture_edge_clamp
                        GL_EXT_texture_env_add
                        GL_EXT_texture_env_combine
                        GL_EXT_texture_filter_anisotropic
                        GL_EXT_texture_integer
                        GL_EXT_texture_lod_bias
                        GL_EXT_texture_rectangle
                        GL_EXT_texture_shared_exponent
                        GL_EXT_texture_snorm
                        GL_EXT_texture_sRGB
                        GL_EXT_texture_swizzle
                        GL_EXT_transform_feedback
                        GL_IBM_texture_mirrored_repeat
                        GL_INTEL_map_texture
                        GL_INTEL_performance_queries
                        GL_NV_blend_square
                        GL_NV_conditional_render
                        GL_NV_primitive_restart
                        GL_NV_texgen_reflection
                        GL_SGIS_generate_mipmap
                        GL_SGIS_texture_edge_clamp
                        GL_SGIS_texture_lod
                        GL_WIN_swap_hint
                        WGL_ARB_buffer_region
                        WGL_ARB_create_context
                        WGL_ARB_extensions_string
                        WGL_ARB_framebuffer_sRGB
                        WGL_ARB_make_current_read
                        WGL_ARB_multisample
                        WGL_ARB_pbuffer
                        WGL_ARB_pixel_format
                        WGL_ARB_pixel_format_float
                        WGL_EXT_depth_float
                        WGL_EXT_extensions_string
                        WGL_EXT_pixel_format_packed_float
                        WGL_EXT_swap_control
                        WGL_EXT_swap_control_tear
                        Core features
                        v3.0 (100 % - 23/23)
                        v3.1 (100 % - 8/8)
                        v3.2 (70 % - 7/10)
                        v3.3 (70 % - 7/10)
                        v4.0 (21 % - 3/14)
                        v4.1 (0 % - 0/7)
                        v4.2 (0 % - 0/13)
                        v4.3 (0 % - 0/23)
                        v4.4 (0 % - 0/10)
                        v4.5 (0 % - 0/11)
                        OpenGL driver version check (Current: 3.1.0 - Build 9.17.10.4229, Latest known: 9.17.10.4229):
                        Outdated version of display drivers detected
                        According the database, you are might be not using the latest version of display drivers for your video card.
                        No ICD registry entry
                        The current OpenGL driver doesn't expose the SOFTWARE/Microsoft/Windows (NT)/CurrentVersion/OpenGLDrivers registry entry. Unable to detect the driver version, driver revision name and filename.
                        Extension verification:
                        GL_EXT_color_subtable was not found, but has the entry point glColorSubTableEXT
                        GL_EXT_paletted_texture was not found, but has the entry point glColorTableEXT
                        GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableEXT
                        GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterfvEXT
                        GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterivEXT
                        • 10. Re: character animator AIF/GL Error
                          henda19561292
                          I have the same problem, and i;'m trying to setup Glview but it failed,
                          i downloaded character animator 2017
                          what can i  do???
                          • 11. Re: character animator AIF/GL Error
                            oksamurai Employee Moderator
                            All our known solutions to Open GL errors are here: FAQ: How do I diagnose and resolve an OpenGL-related error?
