4 Replies Latest reply on Jun 18, 2015 6:48 PM by abraml93379881
    After newest update, minor adjustments don't work
    doctorkenpoleninja
      I'm not entirely sure of how many of the adjustment bars have this issue, but my personal workflow is that I nudge bars around by clicking on the bar slightly left and right of the current setting, whatever it is be it exposure, saturation, etc etc.  Since the update, I've noticed that minor nudges move the bar, but the numbers don't adjust and the image doesn't change, either.  I have to click and drag the bar in order to see and get the minor adjustments out.  I know, there's a shortcut on the keyboard for this--which I suppose I could learn, but atm due to habits, this is highly annoying.  Has anyone else experienced this?
        • 1. Re: After newest update, minor adjustments don't work
          abraml93379881
          Same issue, looking everywhere for answer.
          • 2. Re: After newest update, minor adjustments don't work
            WobertC Adobe Community Professional
            Using LR-CC 2015 Windows-7
            If I click the mouse on a setting name (eg. the word "Exposure") then I can use the + and - keys to increment. (+/- 10,  +/- 5)
            If I click the mouse exactly on the slider pointer then I can use the Left/Right cursor keys to increment.
            But like you- clicking on the slider either side of the pointer results in a larger increment. (+/- 50-60)
            • 3. Re: After newest update, minor adjustments don't work
              jeanclaudephoto
              Exact same issue here. I work the same way, and it's very quick for me. Why did somebody have to go screw with this??
              • 4. Re: After newest update, minor adjustments don't work
                abraml93379881 Level 1
                I am on a Mac running latest Yosemite. No issues before LR 6.1 update.
                I have a MIDI board that is mapped to adjust the sliders via Pfixer, and that works fine (and is saving my sanity right now).
                Lightroom version: 6.1 [ 1025654 ]
                License: Perpetual
                Operating system: Mac OS 10
                Version: 10.10 [3]
                Application architecture: x64
                Logical processor count: 8
                Processor speed: 2.6 GHz
                Built-in memory: 16,384.0 MB
                Real memory available to Lightroom: 16,384.0 MB
                Real memory used by Lightroom: 1,057.9 MB (6.4%)
                Virtual memory used by Lightroom: 2,477.6 MB
                Memory cache size: 183.1 MB
                Maximum thread count used by Camera Raw: 4
                Camera Raw SIMD optimization: SSE2,AVX,AVX2
                Displays: 1) 2880x1800
                Graphics Processor Info:
                NVIDIA GeForce GT 750M OpenGL Engine
                Check OpenGL support: Passed
                Vendor: NVIDIA Corporation
                Version: 4.1 NVIDIA-10.2.7 310.41.25f01
                Renderer: NVIDIA GeForce GT 750M OpenGL Engine
                LanguageVersion: 4.10
                Application folder: /Applications/Adobe Lightroom
                Library Path: /Users/aelandes/Lightroom/Lightroom Catalog 5/Lightroom Catalog 5-2.lrcat
                Settings Folder: /Users/aelandes/Library/Application Support/Adobe/Lightroom
                Installed Plugins:
                1)  Perfect Layers
                2) Aperture/iPhoto Importer Plug-in
                3) Behance
                4) Canon Tether Plugin
                5) DxO FilmPack 3
                6) DxO FilmPack 3 (64-bit)
                7) Facebook
                8) Flickr
                9) FocalPoint
                10) Genuine Fractals
                11) Leica Tether Plugin
                12) Nikon Tether Plugin
                13) Perfect Effects 4
                14) PhotoFrame
                15) PhotoTools
                Config.lua flags: None
                AudioDeviceIOBlockSize: 512
                AudioDeviceName: Built-in Output
                AudioDeviceNumberOfChannels: 2
                AudioDeviceSampleRate: 44100
                Build: Uninitialized
                CoreImage: true
                GL_ACCUM_ALPHA_BITS: 0
                GL_ACCUM_BLUE_BITS: 0
                GL_ACCUM_GREEN_BITS: 0
                GL_ACCUM_RED_BITS: 0
                GL_ALPHA_BITS: 8
                GL_BLUE_BITS: 8
                GL_DEPTH_BITS: 24
                GL_GREEN_BITS: 8
                GL_MAX_3D_TEXTURE_SIZE: 2048
                GL_MAX_TEXTURE_SIZE: 16384
                GL_MAX_TEXTURE_UNITS: 8
                GL_MAX_VIEWPORT_DIMS: 16384,16384
                GL_RED_BITS: 8
                GL_RENDERER: NVIDIA GeForce GT 750M OpenGL Engine
                GL_SHADING_LANGUAGE_VERSION: 1.20
                GL_STENCIL_BITS: 8
                GL_VENDOR: NVIDIA Corporation
                GL_VERSION: 2.1 NVIDIA-10.2.7 310.41.25f01
                GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
