5 Replies Latest reply on Jun 20, 2015 7:31 PM by CarlosCanto
    Illustrator 2015 changes?
    jsavage77 Level 1
      I don't see any new docs available on adobe's scripting page for AI. Does anyone know if there were any changes to the scripting engine?
        • 1. Re: Illustrator 2015 changes?
          Qwertyfly... Level 4
          Not had a chance to have a good look yet.
          but take a look at:
          Dimensions, EmbedItem, EmbeddedItems
          post back if you find more...
          • 2. Re: Illustrator 2015 changes?
            CarlosCanto Adobe Community Professional & MVP
            I haven't upgraded yet, reading the what's new didn't help getting exited about it
            • 3. Re: Illustrator 2015 changes?
              the creative cloud charts look interesting, not that I have any use for them.
              The 64000% zoom (up from 6400%) is the main sell for me.
              I'm always dealing with very detailed small artwork.
              Sick of having to scale it up to edit then reduce again.
              the recover feature is a plus too.
              • 4. Re: Illustrator 2015 changes?
                Ten A Adobe Community Professional
                There are no new documentation for scripting.
                Here is some new Preference Keys for 2015 edition I ever found.
                CrashRecovery/IdleLoopTimeInterval [int] default=2(min)
                CrashRecovery/AutomaticallySave [bool] default=1
                CrashRecovery/RecoveryFolderLocation [string]
                Performance/EnableThinFilledPaths [bool] default=0
                Performance/AnimZoom [bool] default=1
                Performance/EnableGPU [bool] default=1
                Performance/GPUSupported [bool] default=1
                We can use these keys like below:
                app.preferences.setBooleanPreference("CrashRecovery/AutomaticallySave", 1);
                Ten
                • 5. Re: Illustrator 2015 changes?
                  I finally upgraded, I see a couple of interesting ones in this bunch
                  Application Object
                  CC2014Application.pasteRemembersLayers
                  Data Type: Boolean
                  Adobe Illustrator 19 Type Library
                  Does paste operation remember layers structure?
                  CC2014Application.userAdobeID  (Read Only)
                  Data Type: string
                  The current users adobe id.
                  CC2014Application.userGUID  (Read Only)
                  Data Type: string
                  The current user's GUID.
                  CC2014Application.deleteWorkspace (workspaceName: string ): Boolean
                  Deletes an existing workspace.
                  workspaceName: Data Type: string
                  Workspace Name.
                  CC2015Application.getHelloJSONData (): string
                  Returns the JSON Data required by Hello.
                  CC2015Application.isFillActive (): Boolean
                  Checks if fill is active or not.
                  CC2015Application.isStrokeActive (): Boolean
                  Checks if stroke is active or not.
                  CC2015Application.isTouchWorkspace (): Boolean
                  Is In Touch Workspace.
                  CC2015Application.isUserSharingAppUsageData (): Boolean
                  Is user sharing the application usage data.
                  CC2015Application.launchExtension (extensionID: string ): Int32
                  Launch cep Extension given its ID.
                  extensionID: Data Type: string
                  Arguments for Launching Extension - ID of extension in manifest.xml of corresponding extension.
                  CC2015Application.openCloudLibraryAssetForEditing (assetURL: File , thumbnailURL: File , options:any): Document
                  For Internal Use.
                  assetURL: Data Type: File
                  For Internal use.
                  thumbnailURL: Data Type: File
                  For Internal use.
                  options (optional): Data Type: any
                  For internal use.
                  CC2014Application.resetWorkspace (): Boolean
                  Resets the current workspace.
                  CC2014Application.saveWorkspace (workspaceName: string ): Boolean
                  Saves a new workspace.
                  Workspace Name.
                  CC2015Application.setThumbnailOptionsForCloudLibrary (options:any)
                  For Internal Use.
                  options: Data Type: any
                  Options for the PNG24 export.
                  CC2015Application.showColorPicker (color: Color ): Color
                  Invokes application's color picker.
                  color: Data Type: Color
                  The color to load in the color picker initially.
                  CC2014Application.switchWorkspace (workspaceName: string ): Boolean
                  Switches between workspaces.
                  Workspace Name.
                  CC2015Dimensions
                  Dimensions (height and width) (numbers)
                  Document Object
                  CC2015Document.colorProfileName  (Read Only)
                  Data Type: string
                  The name of the color profile of the document.
                  CC2015Document.embeddedItems  (Read Only)
                  Data Type: EmbeddedItems
                  The embedded art items in this layer.
                  CC2015Document.exportSelectionAsAi (exportFile: File )
                  Export the selection as Ai file.
                  exportFile: Data Type: File
                  The file to export the selection to.
                  CC2015Document.exportSelectionAsPNG (exportFile: File , options:any)
                  Export the selection as PNG file.
                  CC2015Document.importFile (importFile: File )
                  Import the file into current Ai document.
                  importFile: Data Type: File
                  The file to import in the current document.
                  New Enumaration
                  CC2014DocumentLayoutStyle
                  Document layout style types.
                  CASCADE, CONSOLIDATEALL, FLOATALL, HORIZONTALTILE, VERTICALTILE
                  New Documents Method
                  CC2014Documents.arrange (layoutStyle: DocumentLayoutStyle ): Boolean
                  Arranges the documents in the specified style.
                  layoutStyle: Data Type: DocumentLayoutStyle
                  The document layout style.
                  New Class
                  CC2015EmbedItem
                  Base Class: PageItem
                  Embedded artwork item.
                  New Class
                  CC2015EmbeddedItems
                  EmbeddedItems Collection.
                  ExportOptionsPNG24 Object
                  CC2015ExportOptionsPNG24.dimensions
                  Data Type: Dimensions
                  Dimensions in which to contain the resulting raster.
                  ExportOptionsSVG Object
                  CC2014ExportOptionsSVG.artboardRange
                  Data Type: string
                  If SaveMultipleArtboards is true,this will be considered for multi-asset extraction
                  which specifies artboard range.Empty string will extracts all the artboards.Default is empty string.
                  CC2014ExportOptionsSVG.saveMultipleArtboards
                  Data Type: Boolean , Default Value: false
                  All the artboards or range of the artboards will be saved.
                  Layer Object
                  CC2014Layer.absoluteZOrderPosition  (Read Only)
                  Data Type: Int32
                  The absolute drawing order of the layer.
                  OpenOptions Object
                  CC2015OpenOptions.addToRecentFiles
                  Data Type: Boolean , Default Value: true
                  Add this file to the list of recently opened files.
                  PageItem Object
                  CC2014PageItem.absoluteZOrderPosition  (Read Only)
                  Data Type: Int32
                  TextFrameItem Object
                  CC2014TextFrameItem.convertAreaObjectToPointObject (): TextFrameItem
                  Convert Area Type Text Object To Point Type Object.
                  CC2014TextFrameItem.convertPointObjectToAreaObject (): TextFrameItem
                  Convert Point Type Text Object To Area Type Object.
                  CC2015TextFrameItem.generateThumbnailWithTextFrameProperties (textString: string , fontSize: number , textColor: Color , destinationPath: File )
                  Generates the thumbnail with the properties of first character in the text frame.
                  textString: Data Type: string
                  The text string which is to be used in the thumbnail generation.
                  fontSize: Data Type: number
                  The size in points of the text string.
                  textColor: Data Type: Color
                  The color of the text string.
                  destinationPath: Data Type: File
                  The location at which the thumbnail is to be stored.
