4 Replies Latest reply on Jun 18, 2015 12:22 PM by stephenr47713837
    Catalog Preview Folder Size?
    stephenr47713837 Level 1
      Hi
      I am currently cataloguing 130,000 images
      Creating standard previews for all content
      I have 27,000 images left to go and my catalogue preview folder size is 150gb
      Is this normal or am I doing something wrong?
      Thank you
        • 1. Re: Catalog Preview Folder Size?
          ManiacJoe Adobe Community Professional
          103000 image previews at 150 GB total ~= 1.5 MB per image
          At a quick glance that might seem a big large per image, but it will depend on how big your previews are being generated.
          See the "catalog settings" dialog, "file handling" tab.
          • 2. Re: Catalog Preview Folder Size?
            trshaner Adobe Community Professional & MVP
            Check your Catalog Settings. If using LR 6/CC 'Standard Preview Size' should be set to Auto(xxxxpx). If using an earlier version it should be set to the horizontal resolution of your monitor or if unavailable the next higher setting (For 1920 monitor set to 2048). Preview Quality 'Medium' is sufficient and will save some space.
            With my 2560x1440 monitor the standard preview is 3.7 Megapixels, or 3.7 x 3 = 11.1 MB. With a typical 1/7 JPEG compression ratio (i.e. Medium Quality) the Standard Preview file size will be ~1.6 MB.
            • 3. Re: Catalog Preview Folder Size?
              dj_paige Level 10
              With regards to the size of the preview cache, you can't really do something "wrong", it is what it is.
              You do have options, as explained above, to change the size of your preview cache, but you can't say that you are doing something "wrong". The options produce different size previews, not "wrong" or "right" preview size.
              • 4. Re: Catalog Preview Folder Size?
                Hi
                Standard preview size "Auto(1920px)"
                Preview quality "High"
                130,000 images, equals approximately 175gb preview folder size
                These figures may be useful to someone as rough guide
                I will try reducing preview quality to "Medium"
                Thanks for all the replies, much appreciated
