I just downloaded the new AI CC 2015 and it keeps crashing. I can only keep it open for a few minutes before it crashes with the error:
"An application has requested more GPU memory than is available in the system."
I never had this problem with CC 2014. My graphics card is an Nvidia Geforce 650ti with a gig of ram. Anyone else having this problem?
I suggest following actions, please see if this fixes your issue
Win: %appdata%\Adobe\Adobe Illustrator 19 Settings\en_US\x64
Mac: ~/Library/Preferences/Adobe Illustrator 19 Settings/
Rama
Illustrator Team
I just sent the AISniffer file.
I've updated the drivers for my graphics card and removed my AI 19 preferences. Illustrator is still crashing with the same error message. I think it's happening mostly when I've been zooming in.
-Mario
Mario,
What happens if you disable the GPU Performance (by clicking the Rocket Icon in the App bar and deselecting the GPU Performance check box)?
Turning off GPU performance fixed this issue for me.
So far today turning off GPU performance is working.
Isn't this feature supposed to speed things up?
Here's all the info on gpu performance. GPU Performance
Yesterday I thought it was still crashing even after turning off GPU performance. But so far this morning with GPU performance set to off, it hasn't crashed. If I try to switch it on, Illustrator crashes right away. Maybe I only turned off GPU preview yesterday when it was still crashing.
Yes, me too on a 2013 MacBook Pro retina 15" under Bootcamp Windows 8.1. Bloomin annoying - thanks Adobe!
It worked fine until yesterday without turning that off. What I did notice is that with "GPU Performance" enabled, it worked slower and didn't show very fine lines, so all in all a pretty useless piece of functionality.
(For reference)
This - so far - has worked for me as well.
I'm using a GTX 770, with driver version 361.43 which is the most recent as of this post.
Well, yes - disabling GPU acceleration works around the issue but the point is that we shouldn't have to disable it.
Come on Adobe, you can do this - maybe have your Illustrator developers talk to the other product teams who solved this before.
GPU is the answer... turn that off... it stops the crashing...
Same issue. I had this problem as soon as I upgraded. I had my primary drive fail this week, so I did a clean install of Win 10, and this happened within 2 hours of a clean install of Illustrator
For me it happens primarily when cutting and pasting between two illustrator files.
Win 10
i7-2600K
16GB RAM
2 Quardro 2200s (drivers updated as soon as Win was installed)
Hi there,
Same problem here in Illustrator CC 2015 (latest).
I have tried opening files I have edited successfully in the past , they now no longer open with GPU Performance enabled.
It might be worth mentioning the artwork in these files contains dropshadow effects (on about 3 or 4 objects).
When pressing 'more info' ,it pointed me to this Nvidia Page: OpenGL message “Request for more GPU memory than is available"
My system configuration:
W7 64-bit
32GB Ram
2x Nvidia Quadro K2000
Latest Nvidia Driver
(no updates available to Illustrator, so latest version)
We just ran into this and further investigation seems to indicate that this is related to a (very) high screen resolution.
I monitored GPU memory usage using GPU-Z and was able to see that this mainly happens on our brand new 4K LG (running at 4096x2160).
On that system, opening any CMYK illustrator file would instantly drive GPU memory usage above the physically present 2 GB - causing the error and a crash.
Changing document color mode to RGB would bring down GPU memory usage a little (1800 MB) but that seems excessive as well.
Note: the driver version does not make any difference in my experience (tested both our previous standard 347.25 and the current 358.50 versions).
Our other high-res single screen setup is running 3440x1440 and ends up with similarly disastrous memory usage:
CMYK:
Comparison values from our dual screen setup (two 1600x1200) show about half the memory usage even though the overall desktop size is pretty similar (3200x1200):
FullHD + 1600x900 setup (Intel HD 4400) end up at 430 MB
Mike,
This makes a lot of sense. Thanks for reporting back with a clear explanation of your discovery. I hope an Adobe staffer see this.
I have reported this (via Adobe Enterprise support) and have gotten the confirmation that this is a bug and that Adobe's engineering has already fixed the issue.
No ETA on a patch/fix though.
This is horrible. I have a brand new mac that keeps crashing while i'm working on super simple infographics in illustrator cc 2015. While Adobe doesn't fix (I can't believe they haven't fixed yet!) perhaps turning the "GPU" option off might improve things?
Same exact issue. It happens when GPU performance is enabled (NVIDIA GTX 650ti boost 2MB). When using the hand tool to move anywhere within my document, Illustrator will crash. If I disable the GPU performance everything works fine. The issue appeared when I updated the NVIDIA video drivers on 12/21/2015 to version 361.43. Since I have no idea how to roll back to an earlier driver, or the trouble that will cause, I'll just disable GPU performance for now.
Just to throw my hat into the ring and to hopefully raise awareness, I am also getting this fault on a 2015 iMac.
However, my colleague has a 2014 iMac that does not have this issue and we are both using the most up-to-date version of Ai CC. The GPU fix works for me, however, it is frustrating to use that functionality.
Have you read post #12. Maybe that explains stuff for you as well?
Sorry, I didn't read that one properly but after reading that again it does make sense as the 2014 is not Retina
I can't (yet) re-test it myself as I currently don't have access to a 4k monitor - still waiting for the delivery.
I was hoping that the fix I was promised had already been included in one of the recent Illustrator updates but apparently this hasn't been the case.
Kind of a shame that nobody is willing to at least give an estimate when such fixes get rolled out.
And as an update, even after disabling the GPU acceleration, I am still developing this error. Although not a frequent but on file sizes as small as 6MB.
Hi All,
I would like to investigate this issue further and want to have a connect session with you.
If you are available for that please drop a test mail with the link of this forum to rbhunwal@adobe.com
Thanks & Regards,
Raghuveer Singh
Illustrator Team
