6 Replies Latest reply on Jun 22, 2015 11:04 AM by spdorsey6969
    Creating a folder in Finder/Windows using a PS action
    spdorsey6969 Level 1
      I need to build a folder hierarchy on the Desktop and place files in it using a Photoshop action. for instance:
      Master Folder Name
      - High Res
      - Low Res
      - Master
      -- master filename.psb
      Using javascript (so that it's portable between Mac and Windows), is there an simple way do accomplish this? Perhaps a tutorial? I'm having a hard time finding good info in the forums - it keeps asking me to start a new post.
        • 1. Re: Creating a folder in Finder/Windows using a PS action
          I found this script that works and does a lot of what I need. Is there a way to make the folder name "Folder A" inherit the file's name without the extension?
          I also need to figure out how to save specific file types into those specific folders after the master folder has been named.
          Re: Create folder hierarchy
          var target = Folder.selectDialog("Choose a target folder");
          if(!(Folder(target+"/"+"filename")).exists)
                  new Folder(target + "/" + "filename").create();
                  new Folder(target + "/" + "filename" + "/hi-res").create();
                  new Folder(target + "/" + "filename" + "/lo-res").create();
                  new Folder(target + "/" + "filename" + "/master").create();
          • 2. Re: Creating a folder in Finder/Windows using a PS action
            michelr31372089 Level 2
            Can you try this ?
            [Code]
            var folderPath = new Array();
            folderPath[0] = "~/DeskTop/High%20Res";
            folderPath[1] = "~/DeskTop/High%20Res/HR_filename.jpg";
            folderPath[2] = "~/DeskTop/High%20Res/HR_filename.png";
            folderPath[3] = "~/DeskTop/Low%20Res";
            folderPath[4] = "~/DeskTop/Low%20Res/LR_filename.jpg";
            folderPath[5] = "~/DeskTop/Low%20Res/LR_filename.png";
            folderPath[6] = "~/DeskTop/Master";
            folderPath[7] = "~/DeskTop/Master/master%20filename.psb";
            for (var i=0;i<8;i++)
                createFolder(folderPath[i] );
            alert("Done !");
            function createFolder(folderPath)
                var folder = Folder(folderPath);
                if (!folder.exists) folder.create();
                return;
            [/Code]
            • 3. Re: Creating a folder in Finder/Windows using a PS action
              That pretty much does what my script does. It names a hierarchy of folders.
              I need the master folder (~/DeskTop/High%20Res) to inherit the name of the document that is currently frontmost in Photoshop.
              • 4. Re: Creating a folder in Finder/Windows using a PS action
                Chuck Uebele Adobe Community Professional & MVP
                Define the folder you want to rename:
                var renamedFolder = new Folder('/c/theFolder/')
                get your file name and strip off the extension. then:
                renamedFolder.rename(fileName);
                if that folder is being used by another program, it will not rename it, so check that it does change with the folder.exists command.
                • 5. Re: Creating a folder in Finder/Windows using a PS action
                  Sorry, I am not sure to have understood because of my terrible English.
                  In the following code, you have to define High Res ( > 92 pixels per inch for instance).
                  [Code]
                  // MAC Finder ou WINDOWS Explorer, on autorise le double clic  et on fait passer Photoshop au 1er plan
                  #target photoshop
                  app.bringToFront();
                  var lowDef = 91; // 92 ppi = high Resolution (for example)
                  var file = app.activeDocument;
                  var master = file.name.substring( 0, file.name.indexOf(".") );
                  var extension = file.name.substring(file.name.lastIndexOf("."));
                  var highRes=false;
                  var resolution = file.resolution;
                  if (resolution>lowDef) highRes=true;
                  file = file.name;
                  var folder = new Array();
                  folder[0] = "~DeskTop/"+master;
                  if (highRes)
                      folder[1] = "~DeskTop/"+master+"/High%20Res/";
                      folder[2] = folder[1]+"/HR_"+master+extension;
                  else
                      folder[1] = "~DeskTop/"+master+"/Low%20Res/";
                      folder[2] = folder[1]+"/LR_"+master+extension;
                  alert("Done !");
                  for (var i=0;i<3;i++)
                      createFolder(folder[i] );
                  function createFolder(deskTopFolder)
                      var folder = Folder(deskTopFolder);
                  [/Code]
                  • 6. Re: Creating a folder in Finder/Windows using a PS action
                    Apparently, this works:
                    var docname = app.activeDocument.name.substring(0, app.activeDocument.name.indexOf('.'));
                            new Folder(target + "/" + docname).create();
                            new Folder(target + "/" + docname + "/hi-res").create();
                            new Folder(target + "/" + docname + "/lo-res").create();
                            new Folder(target + "/" + docname + "/simplified").create();
