1 Reply Latest reply on Oct 22, 2006 4:39 AM by Newsgroup_User
    SOAP Message
    gporto
      I try to send a xml message to a web service deployed in weblogic server 8.1.5.
      My code is:
      public function insertPayment():void {
      var xmlRequest:XML = <insertPayment>
      <hmInsertTask>
      <item>
      <key>beneficiary</key>
      <value>{beneficiary.text}</value>
      </item>
      <item>
      <key>paymentDesc</key>
      <value>{paymentDesc.text}</value>
      </item>
      </hmInsertTask>
      </insertPayment>
      paymentServices.insertPayment({xmlRequest:XML});
      the problem is that server side (in weblogic) the message arrives empty. I log the message and is the following:
      <SOAP-ENV:Envelope xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance">
      <SOAP-ENV:Body>
      <insertPayment xmlns=" http://www.openuri.org/">
      <ns0:hmInsertTask xmlns:ns0=" http://www.openuri.org/">
      <ns0:item>
      <ns0:key xsi:nil="true" />
      <ns0:value xsi:nil="true" />
      </ns0:item>
      </ns0:hmInsertTask>
      </insertPayment>
      </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      Apparently when i nvoke webservice, flex build this message and it ignore the other..
      I hope someone help me
        • 1. Re: SOAP Message
          Level 7
          I'm not sure about Flex, but Flash Professional has a WebService class,
          that makes WebServices a lot easier to use. I guess the class is
          available for Flex as well (but I'm not sure)
          In Flash you can find it under: mx.services.WebService
          - Magnus
          gporto wrote:
          > Hi,
          > 8.1.5.
          > My code is:
          > <hmInsertTask>
          > <item>
          > </item>
          > <item>
          > </item>
          > </hmInsertTask>
          > </insertPayment>
          > <SOAP-ENV:Body>
          > <ns0:item>
          > </ns0:item>
          > </ns0:hmInsertTask>
          > </insertPayment>
          > </SOAP-ENV:Body>
          > other..
          > Thanks
