4 Replies Latest reply on Jun 20, 2015 2:57 AM by 123bea321
    Problem with cc Ball Action
    123bea321
      I have a little problem with my 3D scene. I am making a pixel screen similar to Video Copilot tutorial
      That one:
      Pixel Screen Experiment - YouTube
      My problem is the dirt on the screen. Its just an images on top of my pre-comp with blending mode set to screen. But the problem is that its looks like the images with the dust on is floating in 3D I mean its has the same Z value as my pre-comp (0,0°) that I am trying to lay the images on top of but it looks like it has the value (5°) ore something like that. It looks fake like that so I ask is there is a solution to that?
      I am using Adobe CC
        • 1. Re: Problem with cc Ball Action
          I haven't opened the example file yet (my AE machine is currently busy with C4D stuff).
          A screen would be somewhat in front of the content behind it, so shouldn't it be that way anyway?
          If you really want to adjust it, why not move your dirt layer back?
          Now, if you're talking about the precomp containing CC Ball Action, that layer's position should be at the center of your main comp,  but the CC Ball Action effect might be putting it somewhere else in the layer's z-space if that makes sense.
          • 2. Re: Problem with cc Ball Action
            adamneer Level 2
            Like Szalam said, the CC Ball Action is probably not working in the exact same Z space as the native 3D layers and camera.  And I'll second his suggestion that the simplest solution seems to be just to move the "screen" layer back a few points in Z space, if you want to cut down on the parallax.
            • 3. Re: Problem with cc Ball Action
              What the others said. Unfortunately CC Ball Action does not respond to 3D cameras in the same manner like native 3D layers. Depending on what you actually try to do you may get by with using effects instead of 3D, e.g. by using a corner pin effect and manually warping the dirt into place. Also try to keep the dirt in a separate comp with its own camera and link it with pick-whip expressions to your other comp, then combine everything in another comp. That way you may be able to work around the issue by playing with the focal length or again applying corrective effects on the pre-comp.
              Mylenium
              • 4. Re: Problem with cc Ball Action
                123bea321 Level 1
                Thank you all for the help. Yeah its the Ball Action effects that is making the dirt "float" in the air. I pre-comped the dirt layer and this thing didn't happen I don't know why but it works.
