2 Replies Latest reply on Jun 22, 2015 11:18 AM by JWaguespack
    Yet another Indesign 2015 Problem.
    cbishop01 Level 2
      Is anyone else having insanely Slow performance on this program?  On 2014 WHen i turn on Seperations PReview it Goes right now and very fast response.  Same with Complex artwork Files. On Highest Quality settings.  Now on 2015 It crawls.  I'm saying like 10 seconds to redraw everything.  Is there a fix for this or a setting i can uncheck forthis.  And still keep it at highest setting?
        • 1. Re: Yet another Indesign 2015 Problem.
          cbishop01 Level 2
          I narrowed it down to the Anti Aliasing.  IS there a fix for this?
          • 2. Re: Yet another Indesign 2015 Problem.
            JWaguespack Level 1
            I am having the same issues.  When checking resources, ID2015 uses 600,000KB Memory with freshly reset preferences and no documents open.  Opening 1 simple document jumps usage up to 638,400KB Memory use.  I have display settings on typical.  Last version of CC (2014 version) this was not a problem and memory usage was usually around 100,000KB - 120,000KB.  Redraws when zooming can take up to 20-30 seconds at times for semi-complex art (image layer below 90% transparent vector where vector has drop shadow with 50% transparency set to multiply.
            Note: Memory is only Private Memorey - Commit stands around 904,000KB
            My Work Rig:
            ACPI x64 Based PC
            256GB Solid State - C-Drive
            3TB - E-Drive for file storage
            NVIDIA Quadro k4000 - pushing a 16:9 27" monitor with 2560x1440 res & 2 - 19" 4:3 monitors at 1280x1024 res.
                 -27" and one 19" running off display ports - other 19" on DVI
            CPU = Intel Xeon E5-1650 v2 @ 3.5Ghz (12 Core - 6 Physical)
            16330MBytes (16BG) DDR3 sitting around 930.7MHz
