11 Replies Latest reply on Jun 22, 2015 11:30 AM by rolfsara
    Problems with scripting i Photoshop CC 2015.
    rolfsara
      I updated my Photoshop CC 2014 to 2015 yesterday and immediately noted that my scripts don't work any more.
      I use python for scripting and have built a UI for my script. The script has worked well with Photoshop 6, Photoshop CC, Photoshop CC 2014, but now it doesn't. I get error messages like "object has no attribute 'Preferences'". Many other attributes give error messages as well.
      I had Photoshop 6 installed on my computer as well and I thought I could use that instead but the update seems to have deleted version 6 as well as the previous CC versions. Since I have a purchased version of Photoshop 6, it should not have been deleted since I am supposed to be able to continue using it as long as I want. I have a Photoshop 5 on my old computer and even that works without problems.
      How can I reinstall version 6? Can I revert back to CC 2014?
      Rolf
        • 1. Re: Problems with scripting i Photoshop CC 2015.
          Chuck Uebele Adobe Community Professional & MVP
          You can reinstall old versions with the CC application manager. While it has CS6, that's the subscription version. Sites like Prodesigntools.com have links for old versions of PS.
          • 2. Re: Problems with scripting i Photoshop CC 2015.
            Silver Back Gorilla Level 1
            I'm pretty sure that you will need to contact Adobe support.  I had a similar issue when I discontinued my CC license a while back.  My CS6 stopped working because the CC  had converted my activated perpetual CS6 license to a subscription without asking me to.  It took several re-installations and hours of oversees tech support to get it working.  It was a major pain.  If I remember correctly, the tech support person had to login and run a special program to release the "subscription" from CS6.
            • 3. Re: Problems with scripting i Photoshop CC 2015.
              matias.kiviniemi Level 3
              In addition to using previous versions, if you have the CS6 license key, you can just download the trial image and enter license key
              Download Creative Suite 6 applications
              • 4. Re: Problems with scripting i Photoshop CC 2015.
                rolfsara Level 1
                It looks like I don't have any previous versions of Photoshop on my
                computer. The folders for the previous versions exist, but they are empty.
                The Creative cloud application does not show Photoshop under the previous
                versions tab. Is it still possible to rollback version 2014?
                • 5. Re: Problems with scripting i Photoshop CC 2015.
                  Yes, just install one of them as shown in my previous screen shot.
                  • 6. Re: Problems with scripting i Photoshop CC 2015.
                    Chuck, do you know what happens to the perpetual license in this case when it gets converted to a CC activation?  I had one computer that I cancelled CC on and it would not allow my CS6 perpetual license to run at all, even after re-installing using the original DVD.  I had to work with Adobe support for a week to fix it.
                    I have another computer that had a CS6 perpetual license but it got swallowed up by the CC license as well. It does this automatically when CC is installed.  It just converts the installed CS6 perpetual license to a subscription without telling you or asking you.  I can't deactivate the original CS6 perpetual license.  It allows me to sign out from CS6 which also signs out from CC.  This is an old computer and I want to both sign out of CC AND deactivate CS6 license.  I don't want the CS6 license to be using one of it's 2 activations on a computer that isn't being used.
                    Basically, will the CS6 license still have 1 activation being used up because it doesn't allow me to deactivate this?  Last time around, I could not get a very clear answer to this when I talked to support.  They only have online chat support for perpetual licenses now. There is no phone support for perpetual licenses anymore which is a bit frustrating.
                    • 7. Re: Problems with scripting i Photoshop CC 2015.
                      I don't know that. I've also got a perpetual CS6 license, and I made sure I didn't remove all my old programs. Frankly, even though it's on my computer, it might have been converted to subscription also. Sounds like Adobe needs better license management in their software. I'm assuming that they think that if you subscribe, you won't be using CS6, so they didn't really bother writing code to make use your perpetual license stays perpetual. One of these days, I might run into this issue, but for now, I'm being very careful not to uninstall it.
                      • 8. Re: Problems with scripting i Photoshop CC 2015.
                        rolfsara Level 1
                        I have the same problem with CS6. Up to Photoshop CC 2014 both CS6 and  CC
                        2014 were available. I have some older plugins which don't work on CC 2014
                        so I used CS6 for these.  I want in other words to use both CS6 and CC 2014
                        versions of Photoshop. After I installed CC 2015 both my CS6  AND my CS6
                        plugins were erased.
                        If I now reinstall the CS6, will it disappear again when I manage to
                        rollback my Photoshop CC 2014?
                        I haven't been able to reinstall the CC 2014 because I can see just one
                        Photoshop icon in the CC control window. and with this I can only open
                        Photoshop. My CC window looks like this:
                        http://ankkurinet.org/Transfer/CC.jpg
                        As I understand it, there should be a Ps icon under the versions tab as
                        well with which I would be able to reinstall CC 2014. Are there any other
                        ways to reinstall CC 2014?
                        I have hundreds of images that I should process with my script but
                        currently I am unable to do it.
                        I can't see the idea behind  disabling my perpetual CS6 licence which I
                        have paid for. Why this change of policy now?
                        I found out that the Ps CC 2015 COM interface does not export all Com
                        objects, just a small subset. In all previous Ps versions from CS6 to CC
                        2014 my python scripts have worked without any problems.
                        My script is a fairly complicated one with a graphical interface so I am
                        very reluctant to rewrite it in JS or Visual Basic.
                        I hope a working solution to my problem  can be found.
                        On 21 June 2015 at 18:26, Silver Back Gorilla <forums_noreply@adobe.com>
                        • 9. Re: Problems with scripting i Photoshop CC 2015.
                          Yes, you can reinstall CS6 and CC2015. I just did that, as I too needed to use CS6 scriptlistener to write a script I need. I uninstalled all my PS apps on my second laptop. I installed CS6 first, then 2015. I did have a hard time finding 2015, after I had uninstalled it, but it was there if you close find previous apps and then select find all apps.
                          • 10. Re: Problems with scripting i Photoshop CC 2015.
                            DavideBarranca
                            Hi Rolf,
                            it's unrelated to your original question I know, but how do you use Python for scripting PS? Sounds interesting - do you use it just for building a UI, interacting with the OS, or PS?
                            Thank you!
                            Davide
                            • 11. Re: Problems with scripting i Photoshop CC 2015.
                              rolfsara Level 1
                              Hi Davide,
                              Python is the programming language I am most familiar with. The UI is for
                              me just an extra bonus. I write all my script for PS in Python. You can
                              google for python and photoshop to find more information.
                              I am currently totally lost because I can't write scripts for Ps 2015 in
                              Python. I haven't given up hope yet, however. I hope I will find a way to
                              use Python with PS. If I succeed, I will post the solution to this thread.
                              Rolf
