1. Re: Edge Animate will preload all the images from image folder automatically?
RoarkyGer Dec 10, 2015 12:53 AM (in response to aergadrg)Same question from me - doesn't anyone know?
I find that my animations DO start before all images are loaded, so sometimes images are missing.
How do I tell edge animate to preload all images?
2. Re: Edge Animate will preload all the images from image folder automatically?
joel_pau Dec 10, 2015 12:59 AM (in response to RoarkyGer)1 person found this helpfulHi,
You can do it using yepnope().
Images are loaded but not displayed, therefore you can add displaying effects.
If you have a sample, i will see you the right code.
3. Re: Edge Animate will preload all the images from image folder automatically?
RoarkyGer Dec 10, 2015 1:25 AM (in response to joel_pau)Thanks for the quick reply.
I simply want to preload all images BEFORE the animation starts. No need to show that something is being preloaded.
Do I have to download a script-extenstion in order to use yepnope()? Or is this already included in the general code?
For the coding: I found something like that to be included in creationComplete:
yepnope({
nope:[
'preload!images/slide1.png',
'preload!images/slide2.png',
'preload!images/slide3.png',
Is this all there is? Will images be preloaded and THEN the animation starts?
4. Re: Edge Animate will preload all the images from image folder automatically?
joel_pau Dec 10, 2015 2:25 AM (in response to RoarkyGer)1 person found this helpfulI found an old file (Edge 5.0.1). You can open using Edge 6.0.0.
Here is one solution:
===> demo file yepnope.zip - Box
You have one example with div tag and another with img tag.
Try it and tell me what happens.
5. Re: Edge Animate will preload all the images from image folder automatically?
RoarkyGer Dec 10, 2015 3:39 AM (in response to joel_pau)Actually, I built in
yepnope({
nope:[
In Firefox it works fine, in chrome it seems that when loaded, the first part of the animation is played much too quickly, as if it was paused and then suddenly let loose.
Your example covers much more than I wanted - I really just want to make sure, all graphics are being loaded before the animation starts.
Thank you for the example, it might come in handy some time ...
6. Re: Edge Animate will preload all the images from image folder automatically?
joel_pau Dec 10, 2015 6:34 AM (in response to RoarkyGer)well, your code doesn't make sense.
Because preload doesn't run. Prefix must be set.
And nope refers to a test. Here you want to load.
7. Re: Edge Animate will preload all the images from image folder automatically?
RoarkyGer Dec 10, 2015 6:57 AM (in response to joel_pau)Oh, I understand - then all makes perfect sense.
I added the script and now it seems to work fine - thank you so much!
