1. Re: Lightroom needs to configure your system for the ( ) plugin
ManiacJoe Jun 19, 2015 9:21 PM (in response to Terry_Straehley)Try starting LR in "admin" mode and see if that helps.
2. Re: Lightroom needs to configure your system for the ( ) plugin
@ADelcorde_Hotmail Jun 20, 2015 2:44 AM (in response to ManiacJoe)See the following (From Jeffrey Friedl blog) Jeffrey Friedl's Blog » FAQ for Jeffrey’s Plugins for Adobe Lightroom . It works for me (I did it once as normal user, once "as administrator", doesn't know if necessary). Probably occurs after you decide to uninstall your previous LR version.
- Every time I start Lightroom, I get a message long the lines of “Lightroom needs to configure your system for the $$$/xxx=....... plug-in.”.
This is an issue with Lightroom's installer; the plugin does not need to be reinstalled.To fix it, either uninstall/reinstall the Lightroom application, or open a command window and run
"C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe" -register
(Do include the quote symbols shown on the line above; also, you may need to adjust the drive name and folder path to match the location of your Lightroom install)
3. Re: Lightroom needs to configure your system for the ( ) plugin
Terry_Straehley Jun 21, 2015 11:22 AM (in response to @ADelcorde_Hotmail)Didn't work for me.
4. Re: Lightroom needs to configure your system for the ( ) plugin
AnthonyBenger Jun 12, 2016 3:58 AM (in response to @ADelcorde_Hotmail)1 person found this helpfulThat did work for me. Thanks
I'll also add that I ran the command prompt as an administrator.
5. Re: Lightroom needs to configure your system for the ( ) plugin
Terry_Straehley Jul 16, 2016 1:44 PM (in response to AnthonyBenger)It works as an administrator. I might add that you may have to use the cd command to get to the Adobe Lightroom folder. Trying to run with the command quoted results in the message "C:\Program is not a valid command."
7. Re: Lightroom needs to configure your system for the ( ) plugin
neilwaybright Nov 7, 2016 12:50 AM (in response to AnthonyBenger)Running the command in a cmd.exe window that had been "run as administrator" finally worked for me. Thanks for the help!
