0 Replies Latest reply on Jan 6, 2007 4:06 PM by JMR4ID
    Accessing Native SQL WebService
    JMR4ID
      I am trying to access a SQL endpoint using a webservice in flex 2. The SQL endpoint is associated with a stored procedure that returns the results of a simple query.
      The webservice in flex appears to load the WSDL but for some reason is not getting the results of the operation. I think this may be a security problem connecting to the webmethod/operation. Is there a way to pass credentials to the webservice. I used the "setRemoteCredentials" but that did not work.
      I used the "setCredentials" and got an error that could not use a direct channel.
      Any thoughts woudl be greatly appreciated.
