5 Replies Latest reply on May 8, 2008 12:08 PM by Just Mary
    Can I call RH_ShowHelp using the topid id instead?
    EmanuelV
      I know that when calling RH_ShowHelp using the following syntax:
      <A HREF='javascript:RH_ShowHelp(0, "context-WebHelp/startpage.htm>Mainwindow", HH_HELP_CONTEXT, 10)'>
      I can use the Map ID (in this case '10') to display a particular help page. However, is there a way to acheive the exact same behavior, but instead of using the Map ID, I would use the Topic ID.
      For example, if I have a help page called Fixing_A_Dent.htm, then the Topic ID assigned by RoboHelp is "Fixing_A_Dent" and the Map ID may be something like "5".
      What I want to do is display that help page in the exact same way as before, but using "Fixing_A_Dent" instead of "5".
      Thanks!
