1 Reply Latest reply on Jun 23, 2015 6:03 AM by try67
    Add page to current pdf file using javascript
    ronakp97773265 Level 1
      Hi , , ,
      In my current application , I need add blank page to my current pdf file .
      Please advise me .
      Notes :I don't need below option
      // Open the source documents:
      var source1 = app.openDoc("/C/source1.pdf");
      var source2 = app.openDoc("/C/source2.pdf");
      // Obtain the OCG order array for each source document:
      var mergedOCGArray = new Array();
      var source1OCGArray = source1.getOCGOrder();
      var source2OCGArray = source2.getOCGOrder();
      // Merge the OCG order arrays into the target array:
      for (var i=0; i<source1OCGArray.length; i++)
      mergedOCGArray[i] = source1OCGArray[i];
      var offset = source1OCGArray.length;
      for (var j=0; j<source2OCGArray.length; j++)
      mergedOCGArray[offset + j] = source2OCGArray[j];
      // Create the target document:
      var target = app.newDoc("/C/target.pdf");
      // Insert source1.pdf:
      target.insertPages({
      nPage : -1,
      cPath : "/c/source1.pdf",
      // Insert source2.pdf:
      nPage : target.numPages,
      cPath : "/c/source2.pdf",
      // Set the OCG order array in the target document
      target.setOCGOrder(mergedOCGArray);
      // Save the target document:
      target.saveAs({
      "/c/target.pdf");
      // Close the target document without notifying the user:
      target.closeDoc(true);
      Thanks in advance ,
      ROnak Patel
