6 Replies Latest reply on Dec 29, 2006 6:11 AM by Newsgroup_User
    fireworks 8 100% CPU issue
    stef25
      im using fireworks 8 to make site mockups. recently, the program has started to react slowly and ctrl alt del shows 100CPU usage with simple things like moving layers around. even just moving my mouse around the image makes the cpu surge. usually it takes a bit of time before it starts to act like this. the png files i create are not more than 5MB in size.
      im using a dell, win xp, 2Ghz, 1GB ram. anyone know what causes this? should i just reformat my pc?
        • 1. Re: fireworks 8 100 CPU issue
          Level 7
          Are you creating more than one page on a single canvas?
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: fireworks 8 100% CPU issue
            stef25 Level 1
            not sure what you mean with page. there is one file open with one canvas with about 50 layers and im only looking at the "original", not "preview" or 2-up or 4-up
            • 3. Re: fireworks 8 100% CPU issue
              Level 7
              That's a big file size and lot of layers! Reduce the number of undo
              steps and clear the History to see if that makes a difference. You can
              change the undo steps via Edit > Preferences, and the History file via
              the History panel menu.
              • 4. Re: fireworks 8 100% CPU issue
                Level 7
                i'm working with FW8 FL8 and DW8 at the same time and the PC gets crazy, but
                works.
                Your problem? the number of layers. 50
                My problem? the one computer factor. Dell Celeron 1,6. Sucks, but works.
                I think hidden layers reduces CPU's usage. If you can't merge some layers
                try to hide the stuff you are not working for now.
                I hope may help
                • 5. Re: fireworks 8 100% CPU issue
                  stef25 Level 1
                  is ImageReady better at dealing with this many layers? the filesize is actually less than 1MB! a bit much than FW can not handle this kind of files ...
                  • 6. Re: fireworks 8 100% CPU issue
                    Level 7
                    Image Ready is not a vector application, where Fireworks is. Vectors are
                    CPU intensive
