11 Replies Latest reply on May 2, 2018 10:26 AM by gkaiseril
    Calculate difference between AM and PM time
    garrettc871
      I'm using a form and I want to have the time between two times calculated. That part works - but I'm having problems getting the data after input has been calculated.
      When you enter a time in hh:MM tt format - I have it so that it's calculated and output in HH:MM format already. It doesn't accept that input however - it just tries to use whatever is originally put in the form. This is currently how I'm capturing data from the two fields I need to take data from. I can take this and have people use military time, but I'd prefer to just take input from the hh:MM tt format.
      var hrsStart = parseInt(this.getField("sTime").value.split(":")[0]);
      var minStart = parseInt(this.getField("sTime").value.split(":")[1]);
      var hrsEnd = parseInt(this.getField("stTime").value.split(":")[0]);
      var minEnd = parseInt(this.getField("stTime").value.split(":")[1]);
      This is how I'm calculating data input into the two fields.
      var time = this.getField("stTime");
      var hours = Number(time.match(/^(\d+)/)[1]);
      var minutes = Number(time.match(/:(\d+)/)[1]);
      var AMPM = time.match(/\s(.*)$/)[1].toLowerCase();
      if (AMPM == "pm" && hours < 12) hours = hours + 12;
      if (AMPM == "am" && hours == 12) hours = hours - 12;
      var sHours = hours.toString();
      var sMinutes = minutes.toString();
      if (hours < 10) sHours = "0" + sHours;
      if (minutes < 10) sMinutes = "0" + sMinutes;
      this.getField("stTime").value = (sHours +':'+sMinutes);
      Is my answer Validation?
      I've also tried to do getHours / getMinutes but the values come up unresolved.
      I will accept any help - even if it's not in line with that solution.  I'm okay with being completely wrong.  =)
        • 1. Re: Calculate difference between AM and PM time
          Have you considered that not only does time need to adjust for am or pm but it may also be affected by the date.
          What happens on the day one switches from winter time to summer time for those areas of the world that adjust their clocks for summer or winter time by an hour. So the time following 1:59am becomes 3:00am and the interval between 2:00am and 2:59am does not exist for local time.
          Have you looked at using the JavaScript date object, which converts each millisecond of time into numeric value along a number line.
          If I were to take a 24 hour format, I would use the civilian 24 hour format since the military is a pure number and JavaScript strips leading zeros unless you force the value to be a string.
          • 2. Re: Calculate difference between AM and PM time
            garrettc871 Level 1
            I have been trying this with the following code:
            var strStart = this.getField("sTime1.5").value;
              app.alert(strStart + "   " + strEnd);
            var strEnd = this.getField("stTime1.5").value;
            if(strStart.length && strEnd.length)
              var timeStart = util.scand("h:MM tt", strStart);
              var timeEnd = util.scand("h:MM tt", strEnd);
              app.alert(timeStart + "   " + timeEnd);
              var diff = sTime.getTime() - stTime.getTime();
              var oneMinute = 60 * 1000;
              var timeleft = Math.floor(diff/oneMinute);
              event.value = timeleft;
            else
              event.value = 0;
            My first alert returns the value of the input.  My 2nd returns null - what's wrong with my code?
            • 3. Re: Calculate difference between AM and PM time
              Your first alert should not work at all because strEnd is not defined at that moment.
              • 4. Re: Calculate difference between AM and PM time
                Also, just the hour is not enough information to define a Date. You need to also define the day, month and year.
                • 5. Re: Calculate difference between AM and PM time
                  garrettc871 Level 1
                  What would be the proper format? h:MM tt mm/dd/yy?
                  The dates should never be different - so I'm not that worried about that.  If a static date works - that's fine with me.
                  I also noticed that, but it does work for some reason.
                  It works as:
                    var timeStart = util.scand("h:MM tt m/d/yy", strStart);
                    var timeEnd = util.scand("h:MM tt m/d/yy", strEnd);
                  else
                    event.value = 0;
                  However, I think I need to input the date in the field as well for it to work - and I don't want to do that.  I want just time.  What's the best way to do this?
                  • 6. Re: Calculate difference between AM and PM time
                    The format doesn't matter as long as it contains those values... Yes, that format should be fine.
                    • 7. Re: Calculate difference between AM and PM time
                      garrettc871 Level 1
                      Is there a way for users to just input like 6:30 am and have any date appended to it?
                      • 8. Re: Calculate difference between AM and PM time
                        You need to add the date portion as a static string in your code. Something like this:
                        util.scand("h:MM tt m/d/yy", strStart + " 1/1/15");
                        • 9. Re: Calculate difference between AM and PM time
                          garrettc871 Level 1
                          I got it to work: I had tried that before and it didn't work - but I applied the same theory to the vars before they're input.
                          strStart = strStart + " 1/1/70";
                          strEnd = strEnd + " 1/1/70";
                            var diff = timeEnd - timeStart;
                            var oneHour = 60 * 60 * 1000;
                            var timeleft = (diff/oneHour);
                            event.value = timeleft.toFixed(2);
                          else
                            event.value = 0;
                          This is the working code for it.
                          • 10. Re: Calculate difference between AM and PM time
                            shantaeg61484121
                            This works for me but I keep getting a daylight savings message / warning. How do I make that go away?
                            • 11. Re: Calculate difference between AM and PM time
                              I see nothing that gives any warning about DST. There are a number of alerts that display the inputted time and assumed entry date.. These were added for some debugging purpose and those lines could either be commented out, changed to print to the JavaScript console, or deleted.
                              You should be aware that this script does not allow for the time interval that includes the change over to or from DST.
                              If you need to account for the change over period for DST then you need to include the date for both the start and end times. Also if the start and stops period are not occurring within the same date or day then you will also need to include the date for the start and end times or force an assumption that the stop time is one day after the start date.
