9 Replies Latest reply on Jun 25, 2015 12:05 PM by EddieLotter
    Error when attempting to reference a method in an instanced COM Object
    wwmee
      I am working with CF 10 on a windows 2008 R2 server. We are attempting to employ the RSA authentication system for logins.
      Essentially, when a user has been authenticated a cookie is placed on their client machine and we use a method of a dll to access the username who has been authenticated.
      The instancing of the COM object and the calling of the getUserName() method works fine in an ASP script; however when the object is instanced in CF and an attempt is made to access the same method an error is thrown.
      I dump the methods of the com object after instancing it using the <CFObject tag. The error is thrown when the getUserName() method or any method for that matter are called. The output is shown below.
      In the past I have had very few problems instantiating COM objects. Any idea why CF10 fails on this object which is 64 bit by the way?
      object of coldfusion.runtime.com.ComProxy
      {13178420-1a25-11d4-b579-005004a92ed0}
      Methods RSAGetWebIDURL([out, retval]BSTR)
      GetTypeInfo([in]UINT, [in]UI4, [out]VOID, [out, retval]VOID)
      GetTypeInfoCount([out]UINT, [out, retval]VOID)
      AddRef([out, retval]UI4)
      RSAGetUserName([out, retval]BSTR)
      QueryInterface([in]USERDEFINED, [out]VOID, [out, retval]VOID)
      RSADeleteTagField(BSTR, [out, retval]BSTR)
      RSAGetTagField(BSTR, I4, [out, retval]BSTR)
      RSASetTagField(BSTR, BSTR, I4, [out, retval]BSTR)
      RSAGetCSRFToken([out, retval]BSTR)
      OnEndPage([out, retval]VOID)
      Invoke([in]I4, [in]USERDEFINED, [in]UI4, [in]UI2, [in]USERDEFINED, [out]VARIANT, [out]USERDEFINED, [out]UINT, [out, retval]VOID)
      RSAGetShellField([out, retval]BSTR)
      Release([out, retval]UI4)
      OnStartPage([in]UNKNOWN, [out, retval]VOID)
      GetIDsOfNames([in]USERDEFINED, [in]I1, [in]UINT, [in]UI4, [out]I4, [out, retval]VOID)
      Get Properties error([out, retval]I4)
      The web site you are accessing has experienced an unexpected error.
      Please contact the website administrator.
      The following information is meant for the website developer for debugging purposes.
      Error Occurred While Processing Request
      An exception occurred when executing a COM method.
      The cause of this exception was that: AutomationException: 0x80010105 - The server threw an exception..
      The error occurred in C:/inetpub/wwwroot/ACAAdvisors/rsatest/RSACookieTest.cfm: line 17
      15 :     <cfdump var="#RSACookieAPI#">
      16 :
      17 : <cfset theUserName=RSACookieAPI.RSAGetUsername()>
      18 :     <cfoutput>
      19 :     <p>
        • 1. Re: Error when attempting to reference a method in an instanced COM Object
          WolfShade Level 4
          This link is for the same error on an MS-SQL server, but it _may_ be related.  Check your DLL to make sure that it isn't the deprecated 32-bit dll.
          HTH,
          ^_^
          • 2. Re: Error when attempting to reference a method in an instanced COM Object
            EddieLotter Level 4
            Try the following:
            <cfset retVal=RSACookieAPI.RSAGetUsername("theUserName")>
            <cfoutput>#theUserName#</cfoutput>
            • 3. Re: Error when attempting to reference a method in an instanced COM Object
              EddieLotter Level 4
              Never mind. I read the parameter list incorrectly.
              • 4. Re: Error when attempting to reference a method in an instanced COM Object
                wwmee Level 1
                The DLL is most definitely 64 bit. This was the first issue I thought to look at. Very strange that the ASP instance works fine. The ASP code is almost identical to the CF.  IE.
                    <b>VBScript RSA Cookie API Sample</b></font><br>
                    <hr size="1" color="#000000">
                    <!-- Create a RSACookieAPI Object -->
                   Dim RSACookieAPI
                   Set RSACookieAPI = Server.CreateObject("Rsacookieapi.RSACookie")
                   <p align=right><a href=<%=RSACookieAPI.RSAGetWebIDURL()%>?logoff?RSArand=<%=RSACookieAPI.RSAGetCSRFToken()% >>Logoff</a></p>
                <p>Hello <%=RSACookieAPI.RSAGetUserName() %>.<p>
                I suspect the problem is in how the Java proxy wrapper is communicating with the DLL. If you go to OLEview and examine the DLL the following is what you observe.
                // Generated .IDL file (by the OLE/COM Object Viewer)
                // typelib filename: rsacookieapi.dll
                  uuid(1317840F-1A25-11D4-B579-005004A92ED0),
                  version(1.0),
                  helpstring("rsacookieapi 1.0 Type Library"),
                  custom(DE77BA64-517C-11D1-A2DA-0000F8773CE9, 100663662),
                  custom(DE77BA63-517C-11D1-A2DA-0000F8773CE9, 1389720109),
                  custom(DE77BA65-517C-11D1-A2DA-0000F8773CE9, "Created by MIDL version 6.00.0366 at Tue Jan 14 22:51:45 2014
                library RSACOOKIEAPILib
                    // TLib :     // TLib : OLE Automation : {00020430-0000-0000-C000-000000000046}
                    importlib("stdole2.tlb");
                    // Forward declare all types defined in this typelib
                    interface IRSACookie;
                      uuid(13178420-1A25-11D4-B579-005004A92ED0),
                      helpstring("RSACookie Class")
                    coclass RSACookie {
                        [default] interface IRSACookie;
                      odl,
                      uuid(1317841F-1A25-11D4-B579-005004A92ED0),
                      helpstring("IRSACookie Interface"),
                      dual,
                      oleautomation
                    interface IRSACookie : IDispatch {
                        [id(0x60020000)]
                        HRESULT OnStartPage([in] IUnknown* piUnk);
                        [id(0x60020001)]
                        HRESULT OnEndPage();
                        [id(0x00000001), helpstring("method RSAGetUserName")]
                        HRESULT RSAGetUserName([out, retval] BSTR* pUser);
                        [id(0x00000002), helpstring("method RSAGetShellField")]
                        HRESULT RSAGetShellField([out, retval] BSTR* pShell);
                        [id(0x00000003), helpstring("method RSAGetTagField")]
                        HRESULT RSAGetTagField(
                                        BSTR Tag,
                                        long Encrypted,
                                        [out, retval] BSTR* pField);
                        [id(0x00000004), helpstring("method RSASetTagField")]
                        HRESULT RSASetTagField(
                                        BSTR Tag,
                                        BSTR Data,
                                        long Encrypted,
                                        [out, retval] BSTR* pCookieHeader);
                        [id(0x00000005), helpstring("method RSADeleteTagField")]
                        HRESULT RSADeleteTagField(
                                        BSTR Tag,
                        [id(0x00000006), propget, helpstring("property error")]
                        HRESULT error([out, retval] long* pVal);
                        [id(0x00000007), helpstring("method RSAGetWebIDURL")]
                        HRESULT RSAGetWebIDURL([out, retval] BSTR* pWebIDURL);
                        [id(0x00000008), helpstring("method RSAGetCSRFToken")]
                        HRESULT RSAGetCSRFToken([out, retval] BSTR* pCSRFToken);
                • 5. Re: Error when attempting to reference a method in an instanced COM Object
                  EddieLotter Level 4
                  That goes back to my initial impression. If the function is returning an HRESULT (a numeric value) then the out parameter has to be supplied.
                  Just for intellectual curiosity, try the suggestion in my first reply and post the result.
                  Cheers
                  Eddie
                  • 6. Re: Error when attempting to reference a method in an instanced COM Object
                    wwmee Level 1
                    Very Interesting. Apparently it wants to see an argument although it is not called for.
                    Now observe the results. You can see the  method in the dump but it throws a method not found error.
                    The RSAGetUserName method was not found.
                    There are no methods with the specified method name and argument types. Check your function and retry.
                    16 :
                    17 : <cfset theUserName=RSACookieAPI.RSAGetUserName("testUser")>
                    18 :     <cfoutput>
                    19 :     <p>
                    Resources:
                    Check the ColdFusion documentation to verify that you are using the correct syntax.
                    Search the Knowledge Base to find a solution to your problem.
                    Browser      Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36
                    Remote Address      127.0.0.1
                    Referrer      http://127.0.0.1/WebID/IISWebAgentIF.dll
                    Date/Time      25-Jun-15 11:13 AM
                    Stack Trace
                    at cfRSACookieTest2ecfm276730541.runPage(C:/inetpub/wwwroot/ACAAdvisors/rsatest/RSACookieTes t.cfm:17)
                    coldfusion.runtime.com.MethodSelectionException: The RSAGetUserName method was not found.
                        at coldfusion.runtime.com.ComProxy.invoke(ComProxy.java:518)
                        at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2428)
                        at cfRSACookieTest2ecfm276730541.runPage(C:\inetpub\wwwroot\ACAAdvisors\rsatest\RSACookieTes t.cfm:17)
                        at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:244)
                        at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:446)
                        at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
                        at coldfusion.filter.IpFilter.invoke(IpFilter.java:64)
                        at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:451)
                        at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
                        at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                        at coldfusion.filter.PathFilter.invoke(PathFilter.java:112)
                        at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
                        at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:79)
                        at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                        at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                        at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58)
                        at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                        at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                        at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
                        at coldfusion.CfmServlet.service(CfmServlet.java:219)
                        at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:303)
                        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
                        at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                        at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:241)
                        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
                        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
                        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
                        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
                        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
                        at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
                        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
                        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422)
                        at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:199)
                        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:607)
                        at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
                        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
                        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
                        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
                        at java.lang.Thread.run(Thread.java:722)
                    Debugging Information
                    ColdFusion Server Standard    10,0,15,292620
                    Template    /rsatest/rsacookietest.cfm
                    Time Stamp    25-Jun-15 11:13 AM
                    Locale    English (US)
                    User Agent    Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36
                    Remote IP    127.0.0.1
                    Host Name    127.0.0.1
                    Execution Time
                    Total Time    Avg Time    Count    Template
                    11 ms    11 ms    1    C:/inetpub/wwwroot/ACAAdvisors/Application.cfm
                    7 ms    7 ms    1    top level C:\inetpub\wwwroot\ACAAdvisors\rsatest\RSACookieTest.cfm
                    7 ms    7 ms    1    CFC[ C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc | getThePendingApplicantRecord() ] from C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc
                    1 ms    1 ms    1    CFC[ C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc | getData() ] from C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc
                    1 ms    1 ms    1    CFC[ C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc | getData3() ] from C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc
                    0 ms    0 ms    1    CFC[ C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc | getData2() ] from C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc
                    0 ms    0 ms    1    CFC[ C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc | getData4() ] from C:/inetpub/wwwroot/ACAAdvisors/admin/acaaccess.cfc
                    14 ms         STARTUP, PARSING, COMPILING, LOADING, & SHUTDOWN
                    32 ms         TOTAL EXECUTION TIME
                    red = over 250 ms average execution time
                    Exceptions
                    11:13:03.003 - Object Exception - in C : line -1
                            The getClass method was not found.
                            The toString method was not found.
                    11:13:03.003 - Object Exception - in C:/inetpub/wwwroot/ACAAdvisors/rsatest/RSACookieTest.cfm : line 17
                    • 7. Re: Error when attempting to reference a method in an instanced COM Object
                      EddieLotter Level 4
                      I'm beginning to think your problem is not necessarily specific to that DLL.
                      Have you successfully tested other COM objects? As a process of elimination, try some of the examples detailed in the ColdFusion Developer's Guide.
                      Cheers
                      Eddie
                      • 8. Re: Error when attempting to reference a method in an instanced COM Object
                        wwmee Level 1
                        The developers guide uses the CDO package as an example. I do not have Office 2007 on my server so I cannot install the CDO package to do the mail test.
                        Are there any other examples of DLLs that you can think of?
                        Regards,
                        Bill
                        • 9. Re: Error when attempting to reference a method in an instanced COM Object
                          EddieLotter Level 4
                          See this page: https://wikidocs.adobe.com/wiki/display/coldfusionen/Creating+and+using+COM+objects
                          There are examples instantiating the "CDONTS.NewMail" and "Scripting.FileSystemObject" classes. Hopefully at least one of them will work for you.
                          Cheers
                          Eddie
