7 Replies Latest reply on Jun 24, 2015 10:33 PM by Laubender
    Ink limits busted by transparency
    flaming1 Level 2
      We always place RGB images in Indesign and convert to CMYK on output - normally without any issues. Our elements created within Indesign are always specified as CMYK.
      However, we have an Indesign CC file that I'm struggling with. The file is set up with a 300% ink limit profile assigned. The ad consists of a full page image with text and logos placed over the top. We have successfully output the file in the past with no issues, but now the designer has added a gradient over the bottom of the image to aid legibility of some new small text. The gradient is built from a base colour of 50/0/70/100 and is multiplied over the image.
      Now where the darker part of the gradient hits some shadowed areas of the image the ink coverage is getting up to around 340%.
      Is there a way to fix this, without having to adjust the photoshop file?
        • 1. Re: Ink limits busted by transparency
          There has to be a conversion for the ink to be limited, so multiplying a dense CMYK color over an image can create total ink problems. There are a couple of possible solutions, maybe someone else will have a better one.
          You can set the Transparency Blend Space to RGB, and InDesign's Separation Preview will show the ink limit is being honored because the readout shows the CMYK numbers for flattened document CMYK. The RGB blend space forces all the transparency into RGB and the Sep Preview readout is the conversion back to flattened document CMYK.
          If you have black text on the page, it will also read as 4-color black which you probably don't want. Try exporting the page to PDF/X-4 and in AcrobatPro flatten the page with the Flattener Preview tool (keep the blend space as RGB). In that case the black text should remain black:
          This is a PDF/X-4 page with live transparency and an RGB blend space showing an area of ink at 345%
          The page flattened using Flattener Preview and the same area reads as 300%—SWOP's total ink is being honored.
          Acrobat doesn't convert the black text into 4-color—"some text" doesn't show when I hide the black plate:
          I'm guessing as long as you export PDF/X-4 you don't really need to manually flatten and the conversion would be correct at output, but flattening gives me the right numbers.
          • 2. Re: Ink limits busted by transparency
            flaming1 Level 2
            Thanks for the comprehensive reply Rob.
            Just changing to the RGB transparency blend space makes the ink limit issue go away, but it changes the CMYK values of logos etc that are defined in Indesign. Am I doing something wrong, or is that an unavoidable consequence of changing the transparency blend space?
            • 3. Re: Ink limits busted by transparency
              I think for us "normal" InDesign users this problem is unavoidable.
              We could overcome it by using special device link profiles to control maximum TAC (total amount of color) by a CMYK to CMYK conversion in a PDF workflow.
              But this could not be done in InDesign itself and has to be done best on the printer's side.
              Eg. with special tools like Colorlogic's ZePrA Server software.
              Uwe
              • 4. Re: Ink limits busted by transparency
                flaming1 Level 2
                Thanks Uwe.
                I guess we just have to try to address the problem through Photoshop.
                • 5. Re: Ink limits busted by transparency
                  The RGB blend space is forcing the conversion you need to get the ink limit but ID's blending is to the entire page so all the CMYK objects are going to get re-separated.
                  I think you have to get the multiplied blend into the RGB Photoshop file, then you'll get the SWOP total ink.
                  • 6. Re: Ink limits busted by transparency
                    flaming1 Level 2
                    Thanks for clarifying Rob.
                    • 7. Re: Ink limits busted by transparency
                      Depending on your workflow, a tool like Callas's pdfToolbox with added functionality for using device link profiles could be the answer as well.
                      Btw. I am not working for Callas, but I think, looking into will not hurt. A new version of pdfToolbox was announced today together with webinars in English and German.
                      https://www.callassoftware.com/en/products/pdftoolbox?type=product&product=desktop
                      callas DeviceLink Add-on for pdfToolbox Desktop | callas software
                      Integrated DeviceLink profiles | callas software
                      Uwe
