1 Reply Latest reply on Jun 24, 2015 1:30 AM by neeeilhoman
    Crash when open ID CC 2015 after install the update at 17 Jun 2015
    neeeilhoman
      Help!
      ERROR:
      Unable to launch Adobe InDesign as you do not have sufficient permissions to access the preferences folders. Ensure that you have appropriate permissions and then restart Adobe InDesign.
        • 1. Re: Crash when open ID CC 2015 after install the update at 17 Jun 2015
          neeeilhoman Level 1
          I got an answer:
          Try to give permissions to Adobe Indesign Folders
          Step 1:
          In the Finder, choose Go > Go To Folder.
          Step 2:
          In the Go To Folder dialog and type
          ~/Library
          Click Go.
          Step 3:
          Open the Caches Folder > Open the InDesign folder > select Version 9.0 and Right Click to select Get Info
            • Unlock the Security lock in the bottom right hand corner
            • Under Sharing and Permissions, Click the “+” to add User (yourself) will display under Name
            • Under Privilege it will say Read Only, change this to Read & Write
            • Then select the Settings Icon (cogwheel) and Select Apply to Enclosed Items
          Step 4:
          Open the Preferences Folder > Open the InDesign folder > select Version 9.0 and Right Click to select Get Info
          I changed version 11 folder for step 3 & 4 instead of others, then it works.
