0 Replies Latest reply on May 8, 2006 12:02 PM by Newsgroup_User
    ISP has moved servers, now cannot connect through firewall but can at home.
    Level 7
      Recently our ISP has moved servers to a Gentoo box with Apache webserver and
      sftp ftp server for Gentoo.
      Contribute 3 stopped working, but it's not a simple as a misconfiguration on
      the new server as it looks like at first, because you can edit the site at
      my home using the same Tablet PC that fails at work, so it seems that our
      corporate firewall (Symantec Sygate) and the new host don't seem to be
      communicating properly.
      This is the error log below:
      Contribute Optimized: yes
      ======================== Test Results ==========================
      NOTE: For more information on FTP server compatibility issues, please see
      http://www.macromedia.com/support/contribute/ts/documents/ftp_info.htm
      Login: SUCCESS!
      Changing Directory To: / SUCCESS!
      Directory Listing Test: SUCCESS!
      Make Directory Test: SUCCESS!
      Change Directory Test: SUCCESS!
      Upload a File Test: SUCCESS!
      Fallback Test for Optimization: SUCCESS!
      Server State Test: SUCCESS!
      File/Directory NameExists Test: SUCCESS!
      File/Directory NOT Exists Test: SUCCESS!
      Rename Test: RESOURCE_DOESNT_EXIST - File/directory not found, etc.
      ----------------------- FTP log from the last operation
      > CWD /mm_diagnose_67m49
      < 530 Bad command sequence
      > CWD /mm_diagnose_67m49/
      > CWD /
      Cleaning Test File: RESOURCE_DOESNT_EXIST - File/directory not found, etc.
      > CWD /
      Cleaning Test Directory: RESOURCE_DOESNT_EXIST - File/directory not found,
      etc.
      > CWD /
      Any advice greatfully received, our ISP and Firewall support guys are
      helpful blokes so if a change is needed at their and/or our end it will be
      no problem.
      Jonathan McCormack
      Belfast City Council
      ISB Infrastructure Research and Development
      Tel: - 02890 244832
      Email: McCormackJ@BelfastCity.Gov.UK
      http://www.belfastcity.gov.uk/isb
