1 Reply Latest reply on May 9, 2006 9:14 PM by Newsgroup_User
    FlashLite 2.0 FLA memory limit
    HughisHere
      Has anyone successfully published and tested a Flashlite 2.0 app that exceeds 1024k on the FLA file size. The Flash Lite emulator and documention says that the memory limit is 1024k on the SWF file.
      But I am running into serious memory problems just at the point where my FLA might be exceeding 1024K. My SWF file is less than 300K.
      hugh
        • 1. Re: FlashLite 2.0 FLA memory limit
          Level 7
          HughisHere wrote:
          > Hi,
          I haven't worked with FlashLite but I can tell you that the fla size has
          no influence whatsoever to the player behavior. These are really 2
          different worlds: author-time and run-time. The FlashLite player has
          absolutely no knowledge of the fla, only of the swf.
          You should instead look into other areas:
          * Are you using Flash techniques that use lot of memory or are CPU
          intensive? (huge bitmaps, heavy scripts, intensive alpha or gradients, etc.)
          * are you using actionscript functions that are not supported by the
          FlashLite player?
          You may get better answers if you could describe what type of problem
          you are experiencing.
          hth,
          Tim.
