5 Replies Latest reply on Jun 29, 2015 7:41 AM by Dirk Becker
    importXML not working
    rboyarov91 Level 1
      I have a test import working when i explicitly open a template and import...
      var newDoc = app.documents.add();//open(File(TEMPLATE_EXTENSION));
      newDoc.importXML(File(XML_EXTENSION));
      yet when I open up a new doc and try to open up the same xml at the active one, nothing happens...
      var doc = app.activeDocument;
      doc.importXML(File(XML_EXTENSION));
      The xml is imported just fine when done through the file menu. I've played around with xmlViewPreferences and xmlImportPreferences but can't get it to work. I just want it to show up in the side panel with the tags available to be used.
        • 1. Re: importXML not working
          Level 1
          main();
          function main(){
          //xml -  import options
          var myDocument = app.activeDocument;
          var myXMLImportPreferences = myDocument.xmlImportPreferences;
          myXMLImportPreferences.allowTransform = false;
          myXMLImportPreferences.createLinkToXML = true;
          myXMLImportPreferences.ignoreUnmatchedIncoming = false;
          myXMLImportPreferences.ignoreWhitespace = false;
          myXMLImportPreferences.importCALSTables = false;
          myXMLImportPreferences.importStyle = XMLImportStyles.appendImport;
          myXMLImportPreferences.importTextIntoTables = false;
          myXMLImportPreferences.importToSelected = false;
          myXMLImportPreferences.removeUnmatchedExisting = false;
          myXMLImportPreferences.repeatTextElements = false;
          //open  xml file   /*
          var lista = "";
          var _folder = Folder.selectDialog("Select the path...", ""),
              _files = _folder.getFiles("*.xml");
          for(var A=0;A<_files.length;A++)
                      if (_files[A] != null)
                      _files[A].open("read", "text");
                      testq = _files[A].read();
                      _files[A].close();
                      } else
                          return false;
                      myDocument.importXML(File(_files[A]), false);
                      myDocument.xmlElements.item(0).placeXML(myDocument.pages.item(0).textFrames.item(0));
                      document.textPreferences.smartTextReflow = true;
                      app.activeDocument.recompose();
          • 2. Re: importXML not working
            rboyarov91 Level 1
            Unfortunately this didn't work. A note: I am using InDesign 2015. Setting any of the xmlImportPreferences makes the code break. I tried going without changing them and the file was read but never imported. Again it broke on-  myDocument.importXML(File(_files[A]), false);
            • 3. Re: importXML not working
              Level 1
              create text frame in the application file and run the script
              • 4. Re: importXML not working
                rboyarov91 Level 1
                I don't want to populate the document with the tags imported, I want them to show up on the side panel in a tag hierarchy where you can drag them in manually.  My problem is the side panel not showing up when I import the xml doc.
                • 5. Re: importXML not working
                  Dirk Becker Level 4
                  app.select(app.activeDocument.xmlElements.item(0));
