5 Replies Latest reply on Jun 26, 2015 8:32 AM by lolly_slippen
    Scaling Movieclip according to the input from sensor
    lolly_slippen
      Hi there,
      I am new to adobe flash community and new on using the flash language, so pardon me about it.
      I am currently trying to send data from the pressure sensor through Arduino and display it on flash.
      Don't worry about the sensor and Arduino side of it since I have done the coding and communication part of it to flash, now I am trying to do is when the user press the sensor to have the circle ball [movieclip] to scale and expand the size according to the amount of pressure input from the sensor.
      Below is the code I have done so far for the scaling and hopefully is on track, I use the width and height to adjust the size however I received an error that said "call to possibly undefined method CircleGreen".
      Any ideas on what to do is greatly appreciate it , I will play around and let you know if I fix my problem.
      Thank you
      var circleGreen = new CircleGreen();
      a.addEventListener(ArduinoEvent.ANALOG_DATA, onTickk);
      function onTickk(e:ArduinoEvent):void{
        var feetValue:int;
        feetValue = a.getAnalogData(0);  //to get the data from the sensor
        circleGreen.x = -circleGreen.width / 2 + 312;
         circleGreen.y = -circleGreen.height / 2 + 188;
        circleGreen.width = feetValue / 40 ;
        circleGreen.height = feetValue / 40 ;
        addChild(circleGreen);
        • 1. Re: Scaling Movieclip according to the input from sensor
          lolly_slippen Level 1
          I've changed the variable
          var circleGreen = new MovieClip();
          the error for "possibly undefined method CircleGreen" has disappeared but nothing happens, the circle is not resizing, although there are no error displayed. I assume is my logic of the coding is wrong. I will fiddle around more in the hope of finding solution soon.
          • 2. Re: Scaling Movieclip according to the input from sensor
            funkysoul Level 4
            Maybe something like this?
            Assuming that you don't have any movieclip on the stage with the name circleGreen, I just drew it with AS3
            var circleGreen:Sprite;
            function init():void{
                 circleGreen = new Sprite();
                 circleGreen.graphics.beginFill(0x00FF00, 1);
                 circleGreen.graphics.drawCircle(stage.stageWidth / 2, stage.stageHeight / 2,100);
                 circleGreen.graphics.endFill();
            init();
              var feetValue:int;
            //since i don't know what range of values the arduino sensor ouputs, the normalized output should always be between 0 and 1 so you can safely multiply the normalized value with something that fits better.
              circleGreen.scaleX = circleGreen.scaleY = normalize(feetValue) * 4;
            function normalize(value:Number) {
                 var normalized:Number = (value - 0)/(1 - 0)
                  return normalized;
            • 3. Re: Scaling Movieclip according to the input from sensor
              Hi FunkySoul,
              Thanks for replying, I've noticed that you put "stage" in the code, is it necessary to put import.flash.display.stage?
              The arduino sensor analog output has an acceptable range between 0 to 255.
              I've tested the code and when I played in SWF, the circle ball appeared for less then a second and then it disappears.
              • 4. Re: Scaling Movieclip according to the input from sensor
                funkysoul Level 4
                yes the stage needs to be imported, but you can also replace stage.stageWidth and stage.stageHeight with any number you want.
                Regarding the value simply change line 25 to this:
                var normalized:Number = (value - 0)/(255 - 0);
                Yes it makes sense that you only see the circle for less than a second, as it's immediately waiting for user input from the sensor. as soon as you have normalized your sensor values, things should start to look again.
                • 5. Re: Scaling Movieclip according to the input from sensor
                  cool, will tried out after I get back from work in few hours. Thanks a lot funkysoul, will update again in few hours.
