4 Replies Latest reply on Jun 29, 2015 7:31 AM by Loic.Aigon
    Merging xml nodes
    Loic.Aigon Adobe Community Professional
      Hi all,
      I am inheriting XML files where carriage returns create redundant nodes. That is to say that what should be :
      <tag>A
      B
      C
      D
      </tag>
      is actually
      <tag>A</tag>
      <tag>B</tag>
      <tag>C</tag>
      <tag>D</tag>
      I can certainly look for these tags and do the merging somehow but I wanted to double check if there could be any generic way of merging those kind of repeated nodes. Unfortunately XPath implementation won't allow me to use something like following-siblings::tag
      Any idea ?
      Loic
        • 1. Re: Merging xml nodes
          drerol74 Level 2
          Hi Loic,
          for me following-sibling works both with evaluateXpath and during XML import via XSL transformation!?
          e.g. evaluateXPathExpression("./tag/following-sibling::tag");
          Roland
          • 2. Re: Merging xml nodes
            Hi Roland,
            That's good to know. It doesn't seem to work on XML.xpath though. But your input is helpful as I can envision to import XML in a dummy document and do the merging then export again. I wish I could remain on a pure js object though.
            Thanks a lot,
            Loic
            • 3. Re: Merging xml nodes
              drerol74 Level 2
              Hi Loic,
              I have not read your post carefully enough.
              I tried that:
              var _xmlString = "<root><h1>Bold</h1><h2>Bold</h2><tag>A</tag><tag>B</tag><tag>C</tag><tag>D</tag><strong>Strong</strong></root>",
                  _XML = new XML(_xmlString),
                  _followingTags = _XML.xpath("./tag[1]/following-sibling::tag"),
                  _destTag = _XML.child("tag")[0];
              _destTag.insertChildAfter(_destTag.text(),_followingTags.text());
              for(var i = _followingTags.length() -1; i >= 0; i-- ) {
                delete _followingTags[i];
              $.writeln(_XML);
              Result:
              <root>
                <h1>Bold</h1>
                <h2>Bold</h2>
                <tag>
                  A
                  B
                  C
                  D
                </tag>
              </root>
              Perhaps a different approach, but I do not know how the structure looks exactly..
              Roland
              • 4. Re: Merging xml nodes
                Well looks like following-siblings is working with xpath after all. I may have misused it.
                Thanks for your obstination
                Loic
