I am having various problems installing CS6 Design & Web Premium. From the CD, either the installer hangs or it tells me it is a counterfeit (it isn't). From the Web download file, I can't even extract. I get a access violation error.
copy your cd contents to a desktop directory and install from that directory.
Just tried this. I double clicked on "Set-up" I get the following error:
Adobe Installer
We've encountered the following errors:
Installer failed to initialize. THis could be due to a missing file. Please download Adobe Support Advisor to detect the problem.
...Adobe Support Advisor no longer exists.
Any other suggestions and thanks for your help.
Also I tried right-click to Run as Administrator.
start at the top and work your way down applying applicable fixes until your problem is resolved.
if cc (win): https://helpx.adobe.com/creative-cloud/kb/creative-cloud-desktop-application-failed.html
if, your error is:
"Installer failed to initialize. File not found." or "Installer failed to initialize. This could be due to missing files."
first, rename OOBE Folder to OOBE.old.
to find OOBE:
64 bit win OS: Program Files x86\Common Files\Adobe\OOBE
32 bit win OS: Program Files \Common Files\Adobe\OOBE
mac os: HD>library>application support>adobe>caps
mac os: USER>library>application support>adobe>OOB
if that fails or isn't the exact error you see, uninstall, clean (http://www.adobe.com/support/contact/cscleanertool.html) and reinstall.
if you're using a dvd to install:
copy the disc contents to a desktop directory and install from that directory.
if you're using a mac:
1. Try to Create a new user account in Mac with Administrator Priviledges.
2. Login to the New user, Navigate to Mac HD> Application> Utilities> Adobe Installer folder, Locate products like Adobe Reader, Adobe Flash, Adobe Air and un-install them
3. Navigate to User Library> Application Support> Adobe and move Adobe to Trash.
4. Navigate to Mac HD> Library> Application Support> Adobe and move Adobe to Trash.
5. Start the installation again.
if everything applicable above fails, check your installation logs:
http://helpx.adobe.com/photoshop-elements/kb/troubleshoot-install-using-logs-elements.html
I tried this again copy/pasting to an Admin account, and that worked. THanks for your help!
