• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
help with a valuelist
New Here ,
Dec 27, 2006 Dec 27, 2006
I posted yesterday asking a question about deleting some stuff from my DB and somone suggested I use a value list, so basicaly Im getting all the stock number and putting them in a value list, then running a delete statement like this
where NOT IN('#Valuelist(query)#')
Now my problem is it goes through inserts all my records then when I goto do the deletion it just deletes everything in the DB ? what could cause this? I have tried it both way with and without the single quotes but its the same results. The stock number look like this P434-133 so I don't know if thats messing it up or not as well. Anyhow I would really appreciate some help
TOPICS
Advanced techniques
Views
325
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Take a look at the SQL this generates, and then consider the SQL it SHOULD
be generating.
Hints:
1) SQL "IN clause" lists are not quite the same as CF lists.
2) http://livedocs.macromedia.com/coldfusion/7/htmldocs/00000602.htm
Adam
Votes
Translate
Translate
Report
Report
Advocate ,
Dec 28, 2006 Dec 28, 2006
proxim00,
Now that I'm looking at the code again, the problem could be the single quotes you've surrounded your value list with. You want the SQL to read:
WHERE myField NOT IN ('item1','item2','item3')
and it looks like the example you give above would read:
WHERE myField NOT IN ('item1,item2,item3')
If you need to surround each item in the list with single quotes, I would recommend the ListQualify() function.
Again, follow Adam's advice before you run your SQL and output the query SQL to the screen to make sure CF is building the query you really want.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Hi everyone, well I started to look into it more and I ended up useing quotedvaluelist and it seemed to do the trick :)
Thanks for all your help it put me on the right track
Votes
Translate
Translate
Report
Report
Resources
Documentation
