6 Replies Latest reply on Jun 27, 2015 4:46 PM by Just Shoot Me
    Lightroom 5.5
    DanOmaha
      Lightroom 5.5.  I was closing LR and backing it up when my computer locked up and I had to do a hard close.  Now LR gives me this message when I try to launch it: "Lightroom encountered an error when reading from its preview cache and needs to close.  Lightroom will attempt to fix this problem the next time it launches".  I have launched it multiple times and get the same message.  I have restarted the computer and re-launched Lightroom - same response.  What do I need to do to resolve this issue with the preview cache so that I can launch Lightroom?
        • 1. Re: Lightroom 5.5
          Just Shoot Me Adobe Community Professional
          Delete the Preview Cache folder. It is found, located, in the same folder as the LR catalog file.
          It will be named the same as the catalog file, LighroomCatalogName Previews.lrdata. That is a small L not an i.
          Delete the whole folder and look for a file that ends with a .(dot)LOCK extension. If you find one of those delete that also.
          • 2. Re: Lightroom 5.5
            DanOmaha Level 1
            Thank you for the response.  It appears as if  Lightroom 5 is corrupt and may need to be reinstalled.  I seem to recall that Adobe wants some kind of notification in order to remove and reinstall their software.  Can you tell me anything about removal and reinstallation?  I have the Adobe DVD with Lightroom, and my serial numbers...
            • 3. Re: Lightroom 5.5
              Not sure on a Mac. But usually you just delete the program folder/file and reinstall.
              I suggest you download the most current version of LR 5 from here. Product updates
              The most current version is 5.7.1
              If fact you might not need to uninstall the version you now have installed. Just install that 5.7.1 version.
              • 4. Re: Lightroom 5.5
                ssprengel Adobe Community Professional & MVP
                Do what ShootistBond007 said to do:  remove the preview cache and remove the lock file.
                The preview cache is somewhere entirely different from the LR programs to installing LR isn't going to change anything, whereas removing the preview cache may.
                • 5. Re: Lightroom 5.5
                  DanOmaha Level 1
                  You were absolutely right!  All that I had to do (after I deleted the preview file that you recommended) was to install the 5.7.1 update and everything is working smoothly!!  I can't thank you enough - YOU ROCK!!!
                  • 6. Re: Lightroom 5.5
                    You are welcome.
